Honda cel code 9
Old Feb 15, 2010 | 12:27 PM
92GSR HB's Avatar
Default Honda cel code 9
My car recently started throwing cel code 9, and wanted to get some insight before i start going crazy replacing everything. It only seems it only wants to throw it when its super cold and when i come to a stop/idle. Mainly at idle when at a stop light etc. The car will idle down from 1k to bout 500 then throws the code. Plug wires seem fine, all the connection wires at the dizzy look in good shape/connected. The car also has a slight miss sometimes between 2500-3k regardless if the cel is on or not. Which im sure is a direct result of this. Because my car never had it till it random throwing the code. Any input would be nice before i start replacing plug wires,dizzy etc. Thanks
Old Feb 15, 2010 | 01:52 PM
fcm's Avatar
fcm
Old Fart
Default Re: Honda cel code 9
I would pull the plugs one at a time and inspect them to see if I could determine which cylinder is missing, a fouled plug would indicate no spark a lean "looking" plug would indicate no fuel.
A MM&Y of car and any mods would help. 94
Old Feb 15, 2010 | 02:18 PM
cibao2ner's Avatar
cyp sensor..is ur dizzy on time? code nine is cilynder 1 position sensor..it could be ur dizzy that need to be replace...or its not on time..i replaced mines and code went away never came back...but i had a spare..so u might want to do some research 1st before u go spending the money..
Old Feb 15, 2010 | 08:57 PM
92GSR HB's Avatar
I recently changed the plugs not to long ago, guess i could pull them back out and check again. its a 94 integra b20/vtec supercharged tuned on chrome pro. Plugs are gap at .03
Old Feb 15, 2010 | 08:58 PM
92GSR HB's Avatar
Ya i been doing some research, just tryin to get some insight on the symptoms to pin point the problem. Before i go and switch dizzy
Old Feb 17, 2010 | 06:00 AM
Psychoteen101's Avatar
Most likely its the dizzy. Ive had this happen numerous times.
Old Feb 17, 2010 | 06:08 AM
fly_high_gsr's Avatar
99.9% is your dizyy
Old Feb 17, 2010 | 08:29 AM
92GSR HB's Avatar
Thanks guys for the input
vdawg559
Jun 20, 2008 03:10 AM
94allmotor
24
Sep 8, 2007 08:08 PM
That Sob
Sep 2, 2005 09:19 AM
GTScott
Oct 30, 2003 02:20 PM
