Odd idle, vibrations, CEL code 73
Old Oct 28, 2003 | 01:26 PM
GTScott's Avatar
Default Odd idle, vibrations, CEL code 73
Hey guys and gals,
I have a serious problem, I think. I was driving through an intersection and shifted at about 4500, let out the clutch and got back on the gas. The engine continued to rev, which I thought was the tires spinning since it was a little wet out. When it caught, the car thunked like I had just stalled, but continued to drive. I stopped at the next light, and the car was vibrating, and the idle was bouncing between 600-900. Moments later, the CEL came on, and when I checked it, it threw a code 73 (random misfire). But the light is staying on, the idle is still quite bad, and there's is a slight squeaking sound every so often. The car is an RS, with a manual tranny. Any ideas?!? This is my daily driver, and I'm messed up without it!
Any and all help is appreciated!
Thanks, Scott
Old Oct 28, 2003 | 02:30 PM
EL Vap133's Avatar
Default Re: Odd idle, vibrations, CEL code 73 (GTScott)
I had the same code in my EK, check your plug wires, plugs, dist cap and rotor. I replaced my plugs cause they were pretty messed up, reset the ecu and the code went away...
Old Oct 28, 2003 | 02:38 PM
GTScott's Avatar
Default Re: Odd idle, vibrations, CEL code 73 (EL Vap133)
Wow, as it turns out, I'm an idiot...
Despite the fact that the first thing I did upon arriving at home was pop the hood to check for obvious problems, then check the CEL code, I still managed to miss the wildly flailing spark plug wire going to cylinder 3. Plugged her back in, fired her up, all is well.
to acurasquirrel on Team-integra.net for the help.
Old Oct 28, 2003 | 02:51 PM
Chemicalviper's Avatar
Yay ! Good thing it wasnt serious, i love these stories heeh.
Old Oct 30, 2003 | 02:20 PM
GTScott's Avatar
Default Re: (Chemicalviper)
Heh, to apologize to my car I bought her an oilchange, a nice long wash and a new sway bar
89crxsi89
Mar 20, 2010 11:39 PM
92GSR HB
Feb 17, 2010 08:29 AM
god.loves.ugly
Jul 27, 2005 07:32 PM
