did all ex's have d16y8
Old Feb 15, 2010 | 08:32 AM
96sloan's Avatar
Default did all ex's have d16y8
did all of the 92-2000 civc ex models have a d16y8?
Old Feb 15, 2010 | 08:34 AM
300whpej's Avatar
Default Re: did all ex's have d16y8
no, only the 96-00. the 92-95 ex/si's came with a d16z6.
Old Feb 15, 2010 | 08:39 AM
96sloan's Avatar
thank you. im just wondering if 96-00 exs are rare to come by
Old Feb 15, 2010 | 08:58 AM
Bwill9886's Avatar
Not really. Its a civic, so they're everywhere.
I see at least a couple for sale every week.
Old Feb 15, 2010 | 09:51 AM
96sloan's Avatar
of EX's? yea i just want vtec i also have a small trimed turbo im going to slap on and run about small 9lbs of boost
Old Feb 15, 2010 | 10:17 AM
300whpej's Avatar
z6 is a slightly better motor...dont have to worry about a oil pump seizing up on you
Old Feb 15, 2010 | 11:07 AM
slo_hatch's Avatar
92-95 civic ex/si-d16z6
96-00 civic ex-d16y8
civic ex cars are not rare at all...i see more ex cars than i do dx or hx cars. and single cam vtec isnt anything to get excited about lol but from personal experience i like the d16z6 a little better. it seemed like it took a beating alot better than my old ej8 did.
Old Feb 15, 2010 | 11:26 AM
apexi_rsx's Avatar
run p28 ecu with a jumper harness and get a z6. ive been 2 yrs on 10psi with mine with no problems. y7/y8s only have one oil port for the rod bearings as the z6/a6 both have 2 oil ports to lube the rod bearings. nothing wrong using a y8 oil pump. i have had a y8 oil pump on my z6 for 2 yrs and always have sufficient oil pressure cold and warm.
Old Feb 15, 2010 | 11:28 AM
NOFX's Avatar
H-T White Ops
USDM '96-'00 EXes come with the D16Y8. USDM '92-'00 EXes come with the D16Z6. Canadian EXes might be more like DXes in the sense they could have non-VTEC engines.
I've also heard of people mention issues with Y8s but never seen/experienced them to have any issue in particular over the other USDM D-series engines. Specifically they mention the Y8 having fewer oil passages and such.
I've also had my Y8 for seven years without a problem. I had one other Y8 for a year before this one and also experienced no problems.
D-series manual transmissions do often have ISB issues though. I've had a Y7 tranny and a Z6 tranny both with the same issue; it's not limited to one or the other. $20 bearing, but you have to tear the tranny apart to get to it.
Old Feb 15, 2010 | 12:32 PM
Vindicator9000's Avatar
318 Curves, 11 miles
no, not rare at all.
I know a lot of people say that the z6 is a slightly better engine, but my old d16y8 is still running with 200K+ miles on it. It still has solid compression, solid oil pressure, steady idle, and runs like a top... and it's actually fun in my brother in law's 94 CX hatch.
Old Feb 15, 2010 | 12:52 PM
D16SiHatch's Avatar
you might be doing fine with your y8, which is great, but many people can and have attested to the issues they've had with them. my friend had a y8 spin a rod bearing, and a few weeks ago i picked up an ej6 for cheap because it has a y8 that spun a rod bearing and punched a hole through the block.
Old Feb 15, 2010 | 01:06 PM
Oh, I know. I'm not disputing some people have had those kinds of problems with the y8s. I'm just saying that I wouldn't necessarily decide against a y8. All things equal, get the z6, but if the OP wants a 96-00 car, I wouldn't dissuade him from it solely because of the y8.
If you buy a y8 car and never have any problems with it, great! If it spins a bearing, swap a Z6 shortblock into it. Either way, not much of a problem given the current prices of D-series stuff.
Old Feb 15, 2010 | 10:43 PM
NOFX's Avatar
H-T White Ops
Sure, the Z6 might be, according to some, a slightly "better" engine, but remember since they come in older cars you're more likely to run into other age-related issues with the entire car.
The problems Y8s are reported to have in this thread aren't even as common as say, window issues for '96-'00 Civics. Even that isn't so common that they all suffer from it.
Old Feb 16, 2010 | 12:12 AM
hushypushy's Avatar
The Y8 has a better intake manifold. And it's easier to check the oil.
Old Feb 16, 2010 | 05:16 AM
Troof. And I haven't had a window issue in 219K miles either.
Maybe I got one of the good 96-00s lol.
Also Troof. I hate the dipstick on the z6 and on my B series.
ajason24
19
Aug 18, 2013 07:40 AM
96CIVICEX
12
May 8, 2009 09:26 AM
hondaboyitr
40
Sep 6, 2005 11:56 PM
ruthlesstyper
Dec 11, 2004 10:15 AM
Nothing.Special
May 19, 2003 05:15 AM
