NEED HELP INTEGRA ls MISS SHIFT
Old Feb 15, 2010 | 07:53 AM
GSR936's Avatar
Default NEED HELP INTEGRA ls MISS SHIFT
ok long story short i let a buddy of mine. Drive my car down the track and the guy miss shift. he was on 3rd gear and was going to 4th gear but he threw it to 2nd..... he said he put the clutch right in. And now it has a loud ticking comeing from the vavles i took the vavle cover off. And one of the rocker arms had the top bolt come loose. and now it has alot of play still will post a video later today.
Old Feb 15, 2010 | 07:57 AM
GSR936's Avatar
Default Re: NEED HELP INTEGRA ls MISS SHIFT
car sounds like this but ill post my video later.
http://www.youtube.com/watch?v=6EiJnnpD-yI
Old Feb 15, 2010 | 08:10 AM
GSR936's Avatar
ok here are my videos
Old Feb 15, 2010 | 09:28 AM
masintegrafleet's Avatar
wow thats some serious play on the exhaust side
Old Feb 15, 2010 | 09:33 AM
GagnarTheUnruly's Avatar
Sucks. Your buddy did the money shift. Have you had a look yet to see what all got busted?
Old Feb 15, 2010 | 10:10 AM
GSR936's Avatar
i havent done nothing but do yall think it needs a valve adjustment?
Old Feb 15, 2010 | 10:19 AM
Yeah, but that won't solve your problems esp. with that rocker wiggling around like that. IDK what money shifts usually do to these engines, but you should probably have the head off and check the valves and I think you should see if that rocker is busted. At least do a compression test.
Old Feb 15, 2010 | 12:37 PM
nsxtasy's Avatar
H-T Order of Merit
You wish.
Your buddy probably did some very serious damage. The engine will probably need to be replaced or rebuilt. You're looking at a four-figure repair, which your buddy should pay for. And that's why they call it a "money shift". Sucks to be him, huh? That's an expensive lesson for him to learn.
Since he's going to be paying for the repair, I recommend you take it to a competent, professional mechanic who will repair/rebuild/replace the engine properly, so you know it's done right.
And from now on, don't ever let your car be driven by friends who don't know how to drive a manual transmission without destroying the engine.
Old Feb 15, 2010 | 12:44 PM
keepinitrehaal's Avatar
Most likely a rebuild situation. Im with nsxtasy, your buddy should be the one coming out of pocket.
bcphatchback's Avatar
the loose rocker is due to bent valve, its not closing all the way thus not pushing up on the rocker, that's why it wobbles. You may get lucky and just need to replace the head only. Hoping that the piston isn't destroyed from hitting the valve too many times.
03EM2guy
Honda Civic (2001 - 2005)
73
Aug 26, 2006 10:27 PM
kihun_cha
Dec 19, 2005 02:34 PM
akirab16
Oct 10, 2004 03:35 PM
tac379
17
Aug 18, 2003 06:17 PM
