JDM d16 SOHC VTEC...what timing belt, water pump gaskets?
Carpe diem!
originally ordered a d15b from steve at HMO but he called me about 20 mins after I got off the phone with him originally. He was out of D15b's so he upgraded me to a d16 for free. I already ordered all the replacement parts from hondapartsunlimited for the d15. Below is a list of all the **** I got for the d15b, anyone know what parts I will have to change out for the d16? Do I just get replacement parts for a d16z6?
90215-SB0-003 NUT, SELF-LOCK (12MM) (SATO RASHI) $0.70
Tax Amount : In State (8.30%)
2 $1.40 08798-9031 FLUID, MT $4.77
2 $9.54 08798-9015 OIL, MOTOR (10W30) $2.43
4 $9.72 OL999-9011 COOLANT (TYPE 2 BLUE) $9.80
2 $19.60 94109-20000 WASHER, DRAIN PLUG (20MM) $0.43
1 $0.43 94109-14000 WASHER, DRAIN PLUG (14MM) $0.22
1 $0.22 56992-P02-003 BELT, POWER STEERING PUMP (BANDO) $11.57
1 $11.57 11251-P01-004 GASKET, OIL PAN (OTSUKA) $18.54
1 $18.54 15400-PR3-004 FILTER, OIL (TOYO ROKI) $4.93
1 $4.93 08P15-SR0-110 FLOOR MAT *NH1* (BLACK) $39.90
1 $39.90 98079-5614P SPARK PLUG (ZFR6J-11) (NGK) $2.21
4 $8.84 18115-P00-004 GASKET, EX. MANIFOLD (ISHINO GASKET) $16.56
1 $16.56 19301-P08-316 THERMOSTAT ASSY. (NIPPON THERMOSTAT) $15.19
1 $15.19 19305-PT0-000 RUBBER, THERMOSTAT MOUNTING $2.33
1 $2.33 14520-P2A-305 TENSIONER SET, TIMING BELT (KOYO SEIKO) $43.23
1 $43.23 91213-P2F-A01 OIL SEAL (29X45X8) (ARAI) $3.08
1 $3.08 17105-P08-004 GASKET, IN. MANIFOLD (NIPPON LEAKLESS) $11.91
1 $11.91 90305-692-010 NUT, SPINDLE (22MM) $1.27
2 $2.54 08718-0004 HONDABOND HT $8.75
1 $8.75 12030-P07-000 GASKET SET, HEAD COVER $22.65
1 $22.65 91212-P2F-A01 OIL SEAL (31X46X7) $3.45
1 $3.45 38920-P01-003 BELT, COMPRESSOR (BANDO) $9.86
1 $9.86 31110-P2J-004 BELT, ALTERNATOR (MITSUBOSHI) $10.28
1 $10.28 19200-P08-004 WATER PUMP (YAMADA) $57.10
1 $57.10 14400-P08-004 BELT, TIMING (103RU24 A-555) (UNITTA) $31.84
1 $31.84
1 $31.84
everything should be the same you ordered for both engines, they are very close alike. The only thing I noticed is the spark plugs may be a heat range cooler but you wont notice any difference.
Good luck!
Good luck!
exiguitas
May 17, 2012 06:14 PM
explictness
Mar 16, 2007 04:04 AM
