Odb2a LS in 93 EG 4 door - wiring compatibility
Old Feb 14, 2010 | 07:16 PM
xero_xero's Avatar
Default Odb2a LS in 93 EG 4 door - wiring compatibility
ok, so we finished swapping in our budget build LS 4 door. plugged everything up and tried to start it. nothing. NO FIRE to plugs. listed below is complete specs of everything.
**Car**
1993 Civic LX manual
stock d15b7 OBD1 ecu
single cam harness from ecu to shock tower plugs.
**Motor**
1996 LS manual SI trans
ODB2a Engine wiring harness
it will not fire, will not start.
Motor ran fine in the integra, it now will not run because (my guess) of the wiring.
also have pics of the plugs on the shock towers.
Are there wiring differences? does any one have the eg non vtec manual and DC4 ls manual pin out for the shock towers?
Last edited by xero_xero; Feb 15, 2010 at 06:34 AM. Reason: wrong IMG code for damn pics
Old Feb 14, 2010 | 08:14 PM
CivicSpoon's Avatar
Default Re: Odb2a LS in 93 EG 4 door - wiring compatibility
The harness should be just plug and play. Check to make sure you have all your grounds connected, and that your spark plug wires are in the correct order. If that checks out, check for spark and make sure your fuel pump is working.
Old Feb 14, 2010 | 10:16 PM
white_ej6's Avatar
bro there 2 diffrent obd's as far as my concern it will never start you need a step up harness or changing ur harness...that engine would be plug and play on an ek bro
if u would have gotten a 94 ls it would be plug and play...i belive 88-91 obd0 92-95 obd1 and 96-00 obd2 someone correct me if am wrong but i am pretty sure of what am saying bro
Old Feb 15, 2010 | 06:14 AM
xero_xero's Avatar
All i need is the damn pin outs on the eg shock tower and the dc4 obd2a,
everything is working as it should be, all grounds are on, plugs are in, dizzy is in, nothing funny, pulled out of a running car (changed nothing) put it in another running car (removed motor only
the plugs should only have extra pins for the newer sensors on the obd2a which my obd1 ecuy will not recognize any way.
Old Feb 15, 2010 | 08:49 AM
keving85's Avatar
Shouldn't you be using an obd1 ecu out of a manual 95 or 94 Integra if you are staying obd1 in the civic chassis. Like a p75 ecu from an obd1 integ.
I am thinking a obd1 dizzy too. <------- my question too
Old Feb 15, 2010 | 09:14 AM
xero_xero's Avatar
i would if i could, but all i have are 2 integra ls odb2 ecus
Old Feb 15, 2010 | 09:22 AM
freeagent's Avatar
try to use your single cam enigine harness it shouild work fine. and the b7 ecu will work just wont run like planned i have an obd1 p75 if your interested
Old Feb 15, 2010 | 09:25 AM
xero_xero's Avatar
Mi hamster run real fast...
and i really dont want to resort to a single cam harness. these are plug and play, i just need the pin outs for the shock towers. as for the ecu, i know it will not run at its full potential. i will deal with that later.
Old Feb 15, 2010 | 09:41 AM
freeagent's Avatar
single cam harness is plug and play..
obd1 and obd2 are differnt if you just use the single cam harness your keeping the same obd1..
but if you insist your way then have fun with your never ending headache.
what its gonna hurt if you have a single cam harness anyway?
edit: and if you keep the whole motor obd2 its never gonna start with an obd2 dizzy
put the single cam harness on and your gonna need an obd1 ls dizzy
Old Feb 15, 2010 | 01:27 PM
94EG8's Avatar
Seagull Management
Neither one of you guys have a clue. OBD2A integra engine harness + OBD1 Civic underdash/cabin harness + OBD1 ECU = 100% plug and play setup. OBD1 and OBD2 D and B-series distributors are electically identical, the only difference is the physical plug(s). To the OP pinouts are the same, there is no repining involved, check the thermostat ground and make sure its clean and tight. BTW you will also need to unplug the connector plugged into the firewall mounted MAP sensor and plug it into the throttle body mount MAP sensor on the B18.
Edit, to anyone that doesn't believe you can use an OBD2 engine harness in an OBD1 civic or DC Integra, please see exhibit A below:
Old Feb 15, 2010 | 03:42 PM
keving85's Avatar
thanks you helped me out alot on that info. I was keeping an eye on this thread
Old Feb 15, 2010 | 07:12 PM
xero_xero's Avatar
I knew they were plug and play, the usdm obd2 uses more wires than the obd1, but all obd1 necessary sensors are wired, just the obd2 are not, but they are not used any way.
FOR ME the issue was with the ECU, so in turn, swapping it with another ecu (even though it was an auto ecu) it ran the car fine, just threw a CEL.
thanks for any and all help.
Old Feb 15, 2010 | 07:58 PM
freeagent's Avatar
i was very wrong then. i was always told use your stock engine harness and if you have to then modify it accordingly..i guess im eating my words now thanks for the good info
Old Feb 15, 2010 | 08:20 PM
xero_xero's Avatar
i knew they were plug and play, i just needed the pin outs for diognosing the problem.. probing with the volt meter...
Old Feb 16, 2010 | 01:42 PM
keving85's Avatar
Ok so I can use let's say a 96 integ ls motor harness in a 92 civic cx hatch. Then put an obd1 p75 ecu in the car and it will be good. And also then use the dizzy that came with the motor of the 96 integ?
Old Feb 16, 2010 | 02:01 PM
94EG8's Avatar
Seagull Management
Correct.
mug23
Jul 20, 2016 08:33 PM
MattNYC
Feb 1, 2010 09:37 AM
eglized
Jun 20, 2009 05:20 AM
T.Werd
Oct 11, 2001 07:35 PM
