92 Civic B16a hybrids w/ AEM CAI
Old Sep 6, 2002 | 11:29 AM
SloEG's Avatar
Default 92 Civic B16a hybrids w/ AEM CAI
To those who are using the 99-00 Civic Si AEM CAI on their 92 Civic B16a......did you have any minor fitment issue.......pipe rubbing against the hole??? Bracket not positioned properly?? Thanks!
Old Sep 6, 2002 | 12:29 PM
dogpile5's Avatar
25 Year Member
Default Re: 92 Civic B16a hybrids w/ AEM CAI (SloEG)
mine rubs up against the neuspeed upper strut bar, and wore away at one of the ac condenser lines a few months back, all things that are fixable/avoidable if you take the proper measures in advance..
Old Sep 6, 2002 | 01:44 PM
SloEG's Avatar
Default Re: 92 Civic B16a hybrids w/ AEM CAI (dogpile5)
The piping section which goes thru the hole, does it hit the edge of the metal at all?? I removed my ac so I'm not too worried about that.
Old Sep 8, 2002 | 02:12 PM
denshu's Avatar
which intake are you supose to use with a b16 in the eg?
Old Sep 8, 2002 | 02:14 PM
blackANESE's Avatar
Default Re: 92 Civic B16a hybrids w/ AEM CAI (denshu)
Old Sep 8, 2002 | 03:10 PM
nsxmatt's Avatar
Mine rubs maybe a little but not enough to notice. It didn't line up exactly at first and the mount is kinda sideways but if you loosen the clamps by the TB and work it around it will fit fine.
And that pic about the post has been worn into the ground
Old Sep 8, 2002 | 05:12 PM
xtrafastcivic's Avatar
Default Re: 92 Civic B16a hybrids w/ AEM CAI (TYPE EG6)
dremel... for opening up the hole..
Old Sep 8, 2002 | 06:28 PM
SloEG's Avatar
Default Re: 92 Civic B16a hybrids w/ AEM CAI (nsxmatt)
Thanks for all the info guys......just picked one up......the bushing does look all tweaked, but it fits fine. I used the fender lip cover to go around the hole so the piping would not rub.
Sep 5, 2002 03:03 AM
Hard2Find
Mar 14, 2002 08:25 PM
IntegraGSR23
Mar 6, 2002 08:23 AM
SpoonFed
Jan 29, 2002 06:10 AM
friedsqrl
Jan 25, 2002 12:40 PM
