White Fluid in Oil, should I be concerned???
Old Feb 14, 2010 | 03:20 PM
Project Cortez's Avatar
Default White Fluid in Oil, should I be concerned???
I've got a 1992 Honda Accord LX with only 110,000 miles on it. Great car runs good, have all the maintance records from previous owner. Was checking the fluids today and noticed a little white fluid in on the dip stick with the oil. The oil looked good but noticed white fluid at the end of dipstick. Engine and surrouding area look good, no white smoke upon start up. No loss in any fluids (Oil,Trans or coolant) Head gasket leak? Any ideas what it could be and what I should do? Thanks in advance.
Old Feb 14, 2010 | 03:28 PM
redbull-1's Avatar
Default Re: White Fluid in Oil, should I be concerned???
Depending on the how the previous owner drives and the temperature of the area, it could just be a lot of moisture built up in the crankcase. For example, if the previous owner took quick trips, the oil temperature may never have gotten high enough to drive the water out of the oil and into the PCV system.
I would just change the oil and filter and see if that is normal. Occasional longer drives would also help.
Old Feb 14, 2010 | 03:32 PM
gullyctr's Avatar
keep a eye on the coolant the head gasket maybe on its way out....
Old Feb 14, 2010 | 03:48 PM
I'm the second owner of the car the original owner was a little old lady who drove it to the store, friend's house etc.... Sounds good I'll change the oil and filter and keep an eye on it and the coolant levels. I should probably change the coolant too while I'm at it. Thanks guys
Old Feb 20, 2010 | 09:45 AM
98Sdime's Avatar
I would have thought this as well.
Old Feb 20, 2010 | 10:37 AM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
here's your answer^^^^
Here's your evidence^^^^
Old Feb 21, 2010 | 06:46 PM
nus_dogg's Avatar
Yup yup, redbull has it. Thats oil oxidation.
Don't short trip drive it, cause thats how moisture builds up inside the crankcase. If you do it long enough, there will be more water than oil which can result in a serious loss of the engine.
You gotta drive it long enough for the engine to get hot to evaporate that moisture off and send it out of the engine.
Old Feb 21, 2010 | 07:34 PM
nicolaselias's Avatar
Loved
Community Favorite
Goes without saying that you should make sure your PCV system is in good order... Obviously start by changing the valve ($3) and the grommet ($1)
This would of course be in addition to changing your oil, good filter etc...
Old Feb 21, 2010 | 09:22 PM
19Accord97's Avatar
Yup. The more short trips you take the more often you need to change the oil.
Old Feb 21, 2010 | 09:27 PM
YeuEmMaiMai's Avatar
if you change the oil and drive the car normally and the problem returns, then yes you should be worried.
k3ntegra
Sep 21, 2014 05:25 PM
integra_101
May 24, 2013 11:07 AM
KillerElfboy
Sep 14, 2006 06:12 AM
doggworld1233
20
Dec 8, 2005 05:27 PM
mafiaboy757
Sep 14, 2005 08:58 AM
