swap vs refs??
Old Feb 14, 2010 | 02:50 PM
honda.driver.bence's Avatar
Default swap vs refs??
if i swap a k series in in a 96 or newer car (obd2) what setup if any will pass the emissions test? pa has a obd2 link that reads readiness monitors, vin, and check engine light status. will the k-pro pass these. any help would be great. i plan on DD this car so 5k exempt is out of the question
Old Feb 15, 2010 | 03:58 PM
Default Re: swap vs refs??
any body? bump
Old Feb 15, 2010 | 05:01 PM
20-EM2-05's Avatar
From what I know, K-PRO won't even come close to passing the ref.
I've heard the EM2's being able to ref K series, but haven't actually seen one.
Old Feb 16, 2010 | 04:37 PM
thanks for the input...bump
Old Feb 16, 2010 | 05:54 PM
Rogue_1's Avatar
the car will obviously be modified.. unless the car originally came with that style motor they should be testing it as a hotrod..much easier to pass under this as old cars r a hell of a lot more dirtier with emissions
Old Feb 24, 2011 | 05:00 PM
its been a while since i visited this. just wanted to bump it to see if anyone had any new light to shine on the subject.
Old Feb 24, 2011 | 05:17 PM
delsizzle1's Avatar
the deal with passin the refs inspection to to pass the swap... absolutely no wiring tucking, ur guna need all the emissions control from whatever year car the motor came out on, sometimes even the fuel tank and pump, swap has to be installed professionally not no ghetto half *** swap u knw it has to look like it was done right, it has to pass the smog like it would if it was in its original chasis, and no computer tunes. other than that it should be good
Old Feb 24, 2011 | 06:13 PM
ekb16's Avatar
i don't think you will pass ref unless you plan to throw a rsx/ep fuel tank in your trunk. the k series is a returnless style fuel system
Old Feb 24, 2011 | 06:40 PM
92lxsleeper's Avatar
he's in PA, not california. he doesn't have to worry about the fuel tank bull. you should just grab the entire rsx-s harness and use the oem computer and it will pass no problem
Old Feb 24, 2011 | 11:49 PM
delsizzle1's Avatar
oh well thn yea tht makes a difference lol my bad.... im not to familiar with the smog laws out there
Old Feb 24, 2011 | 11:57 PM
delsizzle1's Avatar
and u knw u can always call the dmv and talk to one of the refs or get their actual phone number and ask wht is it tht ur guna need
Old Feb 25, 2011 | 04:04 AM
grumblemarc's Avatar
The Grumpiest
Yeah. Like a whole year. Are you actually planning on ever DOING the swap?
Old Feb 28, 2011 | 04:39 PM
well to be completly honest, i am a lisenced emmissions inspecter (meaning i look at said car, run through a state computer and either it passes or fails, i just didnt know what i had to do as far as a computer? can i use a stock computer for emmissions then switch to hondata for daily driving? will the car run with swap on oem computer?
Old Feb 28, 2011 | 04:51 PM
i know for a fact the the dot computer has to plug into obd2 port, and it reads, mil status (off to pass), vin (not a big deal if it doesnt match), and the biggest thing im worried about is the readiness monitors, 96-00 your aloud 2 not set (untested emissions items), and 01 + only one is aloud to be untested. now i have some checking to do, some one said change reg. to hotrod, got to see if its even worth it or possible, driving restrictions ect.
Old Feb 28, 2011 | 04:56 PM
cant rush perfection. lol. but yes i still plan on doing swap. just wanna do my home work before i blow wads of cash for no reason, and i got two kids moneys tight
Old Feb 28, 2011 | 05:04 PM
The Grumpiest
Sure. Yeah. Right.
From 2007. In the FAQs.
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-how-k20-into-92-00-civic-94-01-integra-2059720/
ECU note: If you have a US K20 swap (such as Type S or base model K20), you will need to have your ECU K-Pro'ed by Hondata, or use another standalone such as AEM EMS, etc.. Reason for this is due to the immobilizer in the ECU. This will not allow you to run your car. However, if you get a JDM ECU such as the DC5-R or EP3 CTR, you will NOT need to have a standalone. The ECU code for DC5-R is PRC.
Old Feb 28, 2011 | 05:12 PM
94EG8's Avatar
Seagull Management
K-pro is supposed to work with the DLC port so it *should* work. If you use the original RSX ECU you will need to wire in the key ring and transponder for the immobilizer, as well potentially swapping in the RSX fuel tank.
AutoXsi2000
Mar 13, 2016 02:11 PM
BRIANxJDM
35
May 11, 2013 09:49 PM
kDA
Aug 9, 2006 10:16 AM
Wazup
Feb 16, 2004 02:25 AM
