headlights on and no cluster & tail lights help!
Old Feb 14, 2010 | 10:58 AM
caiboR's Avatar
Default headlights on and no cluster & tail lights help!
Like the title says, when i turn on my headlights the cluster lights and tail lights go out. Checked the fuses and no blown fuses. The cluster and tail lights only work when the headlights are not turned on.
Old Feb 14, 2010 | 04:01 PM
fcm's Avatar
fcm
Old Fart
Default Re: headlights on and no cluster & tail lights help!
Your combination light switch, [head light switch] is bad. 94
Old Feb 14, 2010 | 04:57 PM
Relic1's Avatar
replace headlight switch, or clean it. --> http://www.b18c5eg.com/how2/lightswitch/
Old Feb 14, 2010 | 05:05 PM
welfarepc's Avatar
also check your running light relay.
Old Feb 15, 2010 | 10:45 AM
caiboR's Avatar
thanks guys.. I'll check up on it...
Old Feb 15, 2010 | 09:01 PM
caiboR's Avatar
What do you mean by the running light relay. Where is this relay found. Only thing I found was the running light fuse located under the dash near the pedals.
Old Feb 15, 2010 | 09:03 PM
caiboR's Avatar
pretty sure it's the headlight switch but don't want to buy it if it ain't the problem. So i want to check all the possiblities first.
Old Feb 16, 2010 | 05:43 AM
fcm's Avatar
fcm
Old Fart
You need to test the output from the switch.
What is the MM&Y of the car?
The park light output from combination light switch on most Honda/Acura is a red/green, (12V+). 94
Old Feb 16, 2010 | 10:05 AM
welfarepc's Avatar
on my 1990 cx, the running light relay is on the passenger side of the car, under the dash, attached to a bracket that is bolted to the center console steel support.
hope that makes sense.
Old Feb 16, 2010 | 08:24 PM
caiboR's Avatar
2000 interga gsr.
mudd_butt
Oct 17, 2008 07:56 PM
civicDX2178
Jun 5, 2006 02:22 AM
prelude1897
Apr 27, 2005 11:09 AM
