Suspension-handling problems
Old Sep 6, 2002 | 11:15 AM
EF_LSVtec's Avatar
Default Suspension-handling problems
My steering seem a bit off after I did my swap and it feels like it easily steers from side to side especially if I hit a bump or those grooves on the freeway. For some reason, it doesnt feel as solid as before and I'm afraid to drive fast which defeats the purpose of getting a strong engine...lol. WILL ALIGNMENT DO THE TRICK? I'm putting it off because I replaced my axles and crossmember and I'm still waiting for a new motor and tranny in a couple of weeks.
Old Sep 6, 2002 | 12:13 PM
keithv's Avatar
Default Re: Suspension-handling problems (EF_LSVtec)
certain toe settings can make the car seem very switchy. it probably is an alignment. you should get one once everything is all done and see if that helps.
Old Sep 6, 2002 | 12:16 PM
EF_LSVtec's Avatar
Default Re: Suspension-handling problems (breaka_1_9)
thanks
Old Sep 6, 2002 | 12:27 PM
FUP23's Avatar
New User
Mine does to man ..Its pretty scary ..one moment everything is ok then pulls like a **** or somethng when you turn...Its very switchy after my swap ....2 hands all the time
Old Sep 6, 2002 | 12:31 PM
EF_LSVtec's Avatar
Default Re: Suspension-handling problems (Devin17)
hahaha, me too, 2 hands bro, especially going over 100mph...do you think its that extra weight? I have front and rear strut bars and rear lower tie...I wonder if I should replace my swaybars too...I'll get my alignment done soon and find out if it gets any better
Old Sep 6, 2002 | 12:58 PM
Perfectionist's Avatar
The extra weight has something to do with it. Also, the engine mounts should be torqued in a specific sequence or vibration or other misalignment may affect handling. Get hold of a Helm's manual. It's spelled out in there.
Old Sep 6, 2002 | 01:07 PM
EF_LSVtec's Avatar
Default Re: Suspension-handling problems (Perfectionist)
Cool...just like your name says, "Perfectionist." We just slapped em and tighten em...lol have a good weekend everyone.
Old Sep 6, 2002 | 01:12 PM
FUP23's Avatar
New User
damn i did to .. pro the reasons for horrible vibrations
Old Sep 6, 2002 | 01:30 PM
RenoRacing's Avatar
thats funny, my car does the exact same thing since i put my motor in, it's almost like it has power steering because it doesn't feel nearly as stiff. i hate it!!!
Old Sep 6, 2002 | 02:17 PM
EF_LSVtec's Avatar
Default Re: Suspension-handling problems (HavokRacing)
It got a bit better/stiffer though after I replaced the crossmember. But still a bit jumpy, unpredictable.
Old Sep 6, 2002 | 02:47 PM
Timmah!!'s Avatar
torque steer
You put more power in the turnig wheels
The more power you have going to the turning wheels the worse it will get
But I do reconmend getting an alighnment
[Modified by azroth, 6:48 PM 9/6/2002]
Old Sep 13, 2002 | 07:37 AM
IN VTEC's Avatar
If you feel like you're fighting your car all the tight and that it likes to follow grooves, then the tie rods might be damaged...which would make your toe extremely unstable.
Old Sep 13, 2002 | 09:56 AM
Drumwurks's Avatar
Default Re: Suspension-handling problems (IN VTEC)
If you are going to get an alignment done after a motor swap, wait a couple weeks first, to let everything settle with the new parts. Your suspension isn't used to the new weight, or lack thereof.
Getting an alignment too early will be redundent, as things will tend to change on you.
Same goes for lowering.
Old Sep 13, 2002 | 10:02 AM
EF_LSVtec's Avatar
Default Re: Suspension-handling problems (Drumwurks)
Thanks drumwurks...i've been waiting for a couple of months already Everything should be settled in by now...But I will get my tie rods checked and everything else while i get the alignment done.
worx
12
Oct 26, 2012 09:37 AM
ericlee303
Feb 12, 2008 07:49 AM
cbrf-3
12
Jan 20, 2005 08:28 PM
RTW DC2R
Apr 29, 2004 07:21 AM
slixxracing
Nov 30, 2003 08:01 PM
