D engine header question!?
Does the VTEC SOHC ZC (D16Z6) header fit to the DOHC ZC (D16A8, D16A9 and D16Z5) engines??? Anyone who know this for sure? I'm thinking of buying a new header for my car. I want to be sure of buying the right one without any fitting problems! Are the ports matching also?
Thanks for the help, guys!
No use having a header that fits, but doesn't line up with the ports.
This is where you really cant get help bro. Get an exhaust gasket for the head you want to run and check to see if the ports on the header match. If not then port the header flange.
Ok, thanks for the idea but i came here for answers! Sure the best way is to compare the gaskets, thats what I wanted to spare by coming here and asking.
https://honda-tech.com/forums/showth...t#post21938150
You most likely will not need to port match......
good luck....
good luck....
The SOHC ZC / D16Z6 header does NOT fit on the DOHC ZC / D16Z5/A8/A9 engine. U can bolt it on but the ports will not match. I have compared the gaskets.
You may be right, but you really can't tell by the just looking at the gaskets. Most gaskets have to be trimmed to actually fit properly. Check Jlicrx's posts for super accurate info...good luck....
"Most gaskest have to be trimmed?" U sould by genuine honda parts bro...
I've used my own (perfectly fit) gasket to see how it fits on a d16z6 header and it doesnt match up. thx anyways.
fujiwara takumi
Jan 2, 2006 06:21 AM
B18C5-EH2
11
Feb 17, 2005 04:35 PM
