AAAAHHHH!! anyone with engine building knowledge
Old Feb 13, 2010 | 10:04 PM
90honduh's Avatar
Default AAAAHHHH!! anyone with engine building knowledge
ok i bought a d16y8 bottom end and found out it had bad piston rings. i replaced the rings and bearings and went to fire her up it it immediatly jumped to 3000rpm and started blowing white smoke. i made a thread on here and people said it was cooland/ headgasket. i replaced the headgasket and started it again with no antifreeze andi still get the 3000rpm and white smoke and it pours out like a chimney. i have cheacked for vacuume leaks and trial and errored this civ to death. please help!!!!
Old Feb 13, 2010 | 10:09 PM
DustinRose's Avatar
Default Re: AAAAHHHH!! anyone with engine building knowledge
the 3000 rpms is an ignition problem, do you have any trouble codes? (check engine light)
is it white smoke or blue smoke? make sure the PCV i hookep up correctly
Old Feb 13, 2010 | 10:52 PM
D16SiHatch's Avatar
when you installed the new piston rings did you check your ring gap, and did you clock the rings properly? most likely the high idle is related to a large vacuum leak.
Old Feb 13, 2010 | 11:34 PM
90honduh's Avatar
it is blowin white like a cloud. i have no engine code accept for a o2 sensor that was on before the build. and when i found out the rings were bad the first time it had the same idle problem. does it have anything to do with the head? i put a a6 head on a y8 with the a6 intake mani
Old Feb 14, 2010 | 01:34 AM
~sp33~'s Avatar
EFB055
Check for bubbles, or excess pressure in your cooling system. I'd ask if you were losing any coolant, but it would be difficult to tell if the car is only turned on for short periods of time.
While the car is idling, try using a spray gun (set to mist) and spray water around the vacuum lines near the intake manifold. If the engine bogs, you have a vacuum leak and it's a matter of fixing the culprit.
Old Feb 14, 2010 | 05:25 AM
91civisedaner's Avatar
Pardon my Di$kness but you don't wanna spray WATER in or around the intake!! Try carb cleaner if it runs better when you spray theres your leak!!!
Old Feb 14, 2010 | 05:26 AM
~sp33~'s Avatar
EFB055
Why not? It comes out as a mist. It's not like you're ramming a friggen hose in there.
Old Feb 14, 2010 | 05:37 AM
Are ya tryin' ta make his White Cloud Bigger???? then ok
Next yer gonna tell him ta soak his sparkplugs in oil??
Old Feb 14, 2010 | 05:41 AM
~sp33~'s Avatar
EFB055
Are you trying to make the idle higher? Then ok.
There's no problem with what i've mentioned.
Old Feb 14, 2010 | 05:56 AM
Obviously you've NEVER done this cuz the idle will go down when you spray carb cleaner on it!!(with the vacume leak extra AIR is getting in when the CARB Cleaner is sprayed in leak it ADDS fuel and cancels the leak for a split second DER DER repair engines much??? I've been rebuilding cars for 16 years and also worked as a small engine tech for 2years
I'm sorry i just noticed your in australia,maybe vacume leaks go up down there when sprayed with carb cleaner,just like your toilet flushing backwards!!! J/K man I'm not tryin' ta start a fight and I appoligize if i offended ya!!
Old Feb 14, 2010 | 08:35 AM
Red_ED8's Avatar
Theres nothing wrong with what SP33 said. Both suggestions would work fine. On another note, are you sure your rings have set right and haven't washed out?
Old Feb 14, 2010 | 11:04 AM
DCRB's Avatar
great another n00bie arguing with sp33 again.
91civisedaner, did you ever think that by MISTING water around all vacuum sources (which water doesn't evaporate as quickly as carb cleaner does) would also visually reveal a leak because you could see it being sucked in, espescially if you used dye in the water...
o/p, have you ever set your idle properly? it's possible that some one messed with your idle screw... i have a z6 tb that some one messed with the idle screw on it, and when i start my car it jumps right up to 5 grand... scary **** lol
also, are you sure you don't have a vacuum hose and a coolant hose switched up?
Old Feb 14, 2010 | 12:18 PM
90honduh's Avatar
ya. i just found that the pcv valve is broken. does that cause white smoke?
Old Feb 14, 2010 | 02:59 PM
~sp33~'s Avatar
EFB055
Meh, i get used to it.
Old Feb 14, 2010 | 03:44 PM
Je2RiT's Avatar
if it is snapped in half broken then thats your Vac leak.
if you plug it enough to leave some airflow the idle should go normal.
when I forgot to connect mine back up after my new IM it went right to 3k. :-)
culprit of white smoke? dont think so.
Old Feb 14, 2010 | 03:59 PM
1kleenef's Avatar
did u hone the cylinder? or just throw new rings in and hope for the best? Did you measure your bore for taper and wear while you had the pistons out?
Old Feb 14, 2010 | 04:31 PM
EJ1_Sleeper's Avatar
did anyone else catch that? thats like a reverse mini me unless you ment z6?
Old Feb 15, 2010 | 12:06 AM
90honduh's Avatar
no i bought a z6 head off ebay and it would spin. (gotta love ebay). so i put my original a6 head on. yes i got the block honed. i took everything to a local machine shop and had it honed and rods/crank polished. i had help building the motor and the piston ring end gap was correct. do rebuilds smoke durring break in? it has only ran for a total of 10 mins didnt drive it.
Old Feb 15, 2010 | 12:28 AM
hatchet_honda's Avatar
so you dont mind if your engine sucks in water instead of combustible fuel?
Old Feb 15, 2010 | 04:22 AM
~sp33~'s Avatar
EFB055
Old Feb 15, 2010 | 06:42 AM
lunalink's Avatar
lmfao @ the popedon't feed the troll.
Old Feb 15, 2010 | 07:06 AM
Dogginator's Avatar
Daisy... Daisy...
There is not problem with either water or carburetor cleaner sprayed on the intake manifold to detect a leak at idle. Both with vaporize when throttled through a leak. Carburetor cleaner is flammable and warrants greater caution.
Steve-Os-B18
Jan 3, 2011 09:19 PM
Garcia505
10
Sep 4, 2009 08:56 AM
boom32
Jun 5, 2008 04:28 PM
SymphonyX
Mar 18, 2003 09:52 PM
b18tdelsol
Apr 15, 2002 10:16 PM
