CRX Si revs to 6k RPM+ on start up
Old Feb 13, 2010 | 12:21 PM
sonic47's Avatar
Default CRX Si revs to 6k RPM+ on start up
Wassup homies
Got an 89 CRX Si, and I just dropped a d16a6 in it. I'm experiencing the most bizarre problem. As soon as I crank the key and the car starts up, the engine revs up all the way to about 6k RPM immediately and then continues to climb slowly.
So here's everything I've tried so far:
- Swapped ECUs
- Disconnected throttle cable
- Unplugged throttle position sensor
- Remove Idle Air Control (this made the engine jump between 1 and 2.5k RPM)
- Replaced Idle Air Control
- Removed all vacuum lines off of the intake manifold (the engine still shot up to 3k RPM and started shaking)
- Held throttle body closed
- Double checked vacuum lines, everything seems to be correct
So we tried all that and the result is the same everytime; the engine revs up to 6k RPM+. Any ideas?
Thanks in advance.
Old Feb 13, 2010 | 12:22 PM
ef yu's Avatar
Default Re: CRX Si revs to 6k RPM+ on start up
adjust the idle screw?
Old Feb 13, 2010 | 12:58 PM
sonic47's Avatar
Tried that..no luck
Old Feb 13, 2010 | 01:05 PM
beansandrice's Avatar
Check all of the vacum lines and plugs you must have some or all disconnected. Look for the larger sized vacum nipples that connect to the PCV valve etc
Then the IAC and the intake manifold gasket. Where in socal are you?
Old Feb 13, 2010 | 01:21 PM
baby50's Avatar
I smell a huge vacum leak somewhere obvious. Check your throttle body in particular under neath it.
Old Feb 13, 2010 | 01:46 PM
sonic47's Avatar
I followed the Si 1.6 vacuum diagram. The gaskets seem fine. I'll start checking for leaks.
I'm located Azusa.
Old Feb 13, 2010 | 01:48 PM
2point2's Avatar
make sure the pcv valve is working correctly.
Old Feb 13, 2010 | 02:53 PM
sakasaku's Avatar
with engine running Spray Carb a choke cleaner on all Vacuum line and were they hook up and if bogs down when you hit it somewhere theres one of your leaks
Old Feb 13, 2010 | 09:43 PM
sonic47's Avatar
Thanks for the suggestions guys, I really appreciate it.
Just bought a new PCV Valve; I'll install it tomorrow. I'll also check for vacuum line leaks, but I get the feeling that it may not be as simple as a vacuum leak - I'd expect a more subtle abnormality if it was a vacuum leak. This engine is revving up to 6K immediately as if the car was started with my foot already smashed on the accelerator.
I do know that the previous owner of the engine had a skunk2 manifold installed on it and had replaced it back with the stock one when I bought it. So this makes me wonder if the issue lies within the intake manifold, specifically.
Also, does anyone know where I can get a more in depth or detailed vacuum line diagram for D16? Rather than the Honda Manual vacuum line diagram? Thanks!
Old Feb 14, 2010 | 07:36 AM
crex23's Avatar
I know you mentioned the TPS already, but when you do a mpfi swap you have to switch the green and yellow wires around or else the car will shoot to redline. You said your swapping a D16A6 into an Si, so this might not be it, just throwing that out there.
Old Feb 14, 2010 | 12:05 PM
Ya Digg's Avatar
did you put on a new gasket? and torque all the blots down? new throttle body gasket? its obviously a huge leak somewhere.
Old Feb 14, 2010 | 01:27 PM
Foowee's Avatar
Have you actually looked at the the butterfly valve of the throttle body? I know you say you held it closed. Visually inspect it to see if it's broken in half...
Old Feb 14, 2010 | 05:15 PM
my90si29's Avatar
get a new intake an maybe ur problem might be solved
Old Feb 14, 2010 | 09:52 PM
akshn1's Avatar
take off iacv and clean..or clean th throttle boddie (the insideof it )ormaybeu have sum ofyour vaccumm hoses wrong.i had same pob but mine wen to 4k on start up....
Old Feb 15, 2010 | 09:56 AM
1 Civic I's Avatar
I bet its a vac leak or a hose is connected to a wrong end, switch around?
Old Mar 19, 2010 | 04:19 AM
slocrx1984's Avatar
Did anyone ever find out if he fixed the problem? My h22 crx is doing the same thing but I can't find out why?
Old Mar 19, 2010 | 05:16 AM
vanion2's Avatar
For vacuum leaks here is what I do:
Trouble Shooting Vacuum Leaks
Old Mar 19, 2010 | 05:33 AM
Eaglekper0046's Avatar
If you can pressurize the system that should tell you where the leaks are. That what I do for my turbo piping.
http://www.myturbodiesel.com/1000q_h...boostleaks.htm
All you need is 2 hose clamps, rubber coupler, PVC end cap and a valve stem.
FEAR6655
Apr 9, 2011 12:47 AM
crxnonvtec
22
Sep 3, 2009 02:52 PM
shadow29485
Feb 21, 2008 01:36 PM
haroldthefly91crx
Mar 31, 2007 02:09 PM
