Hello fellas! New to the accord world!
Well I just came home with a 92 Honda Accord LX and I have couple questions for ya accord gurus....my very first accord so i know nothing bout accord guys.
1.Well first things first, the previous owner told me that on a hot day with the windows up, the car will crank but will not turn over. What she did to get the car to turn over was, she would open the window and door and let the cabin cool off and then the car will turn over after it had cool off. Some random mechanic told her it might be some type of relay?..any suggestion from you guys would be great..
What I did first right when i made it home. Was a compression test and a wash.
92 Honda Accord LX Coupe 5 Speed.
If by the "brake lamp" indicator you mean the one below where it shows when the doors are open, then one of your brake lamp bulbs isn't working.
yes sir thank you it was the brake fluid level..i filled it up and it went away! thanks...for the main relay part....is there any other car that has relay that is compaitable with the model i have?
At least any other 90 - 93 Accord should have the same relay. I wouldn't recommend a used one - might be as bad as the one you have. You can search for instructions on how to repair the solder joints in the one you have.
thanks for the suggestion...im soo used to just snatching one from the yard and use that.
after i fill her up with brake fluid..both the brake light and brake lamp went away, but now this morning i turn the car on..the brake lamp came back...could this still be the bulb?
^^ owned^^
do you mean the "brake lamp" that show underneath the little car diagram? If so then one of your brake lights is out.
..and your CB7 is sexy!
yes sir that is the one i am talking bout....thank you thank you....i couldnt complain much when the car was almost donated and i was able to make a quick response to it and got it for free with clean title =D....the major plus was...i stick a thermometer into the air vents and blast the ac for the 1 hour ride back..and holy ****, it blew a consistant 39 degrees all the way!
yeah that light means that something is wrong in the brake light assembly. it could be bulbs, contacts, or ground. pull the bulbs and look for corrosion on the contacts. if not check out the grounds. then replace the bulbs if that doesnt fix it. (corrosion, then replace bulbs then check for grounds would be easier, but you may end up buying bulbs you don't need.
the car looks nice btw man. looks like your headlights need restored but thats a cheap and easy fix.
