question about gauge cluster
Old Feb 13, 2010 | 08:33 AM
graffini's Avatar
Default question about gauge cluster
i have a 95 accord ex auto. is there a differnece between a ex and a lx gauge cluster? i know i need to make sure it has the abs light but is there any differnce between the 2?
Old Feb 13, 2010 | 08:59 AM
fleetw00d's Avatar
Default Re: question about gauge cluster
Do you need the whole cluster or just a single component of it? The ones in my 93's are relatively easy to disassemble to swap out components. My wagon had corrosion on the printed circuit board, I was able to get a PCB out of sedan, but the speedos are different between wagon and sedan. I just installed the speedo and PCB from the sedan in the wagon cluster to maintain the odometer.
Old Feb 13, 2010 | 10:26 AM
redbull-1's Avatar
If your problem is the speedo and the odometer works fine, swap the printed circuit board off the back of the speedo head, it just pulls off the speedo head. That way you retain your original mileage. If the problem is a component, just swap the components (e.g., speedo, tach, gas gauge, etc.). Swapping a part of the cluster is your best bet, as you don't have to look for only one from an EX.
When I had a 95 EX before, I swapped the entire cluster from a LX. The LX cluster is basically the same as the EX, with the exception of the black plastic bezel, which you can swap (the LX bezel covers the ABS light) and maybe a missing ABS bulb. I only realized I could have just replaced the printed circuit board on the back of the speedo after the LX cluster was in and I disassemble my EX cluster after it was out.
Old Feb 13, 2010 | 11:55 AM
davey5300's Avatar
I hear that the lx and Ex spedo's are different
Old Feb 13, 2010 | 01:37 PM
graffini's Avatar
ya i just got the car a month ago and the speedo, gas needle is missing, and thermo dont work. the odometer work and the rpm gauge works thats it
Old Feb 13, 2010 | 02:49 PM
redbull-1's Avatar
They're the same, I had the speedo from an LX in my previous EX. My nephew has it now. It been working for 5 years that way now.
sk8shorty012
21
Mar 11, 2011 05:03 PM
eseries07
Honda Civic (2001 - 2005)
Dec 24, 2008 08:59 AM
95 GSR B20VTEC
Oct 29, 2008 11:43 PM
ctr status
Mar 9, 2008 12:13 PM
