k20a3 head work
ok so i found a deal on skunk 2 stage 3 cams and Supertech titanium spring and retainers both never open from the box for 700 dollars. since my ep has hadd bad cam wear and im replacing the block as soon as i can find one, do you think this is worth it? i gonna need kpro thats for sure right? will the stock valves clear with stock pistons? low compression motor i dont see why not. or am i just wasting money, and go for a2, i still need a clutch and flywheel and throw bearing. and it burns oil so i have get rings... ughh im so lost need some guidance please
Don't waste your money on those cams, fix your issue's first, or swap out the motor for and A2 motor and transmission that would be your best option and most bang for your buck.
This would have been a bad idea for you in more ways than one. Stage 3 cams on a motor that has low compression and a low rev limit is pointless. You will get nothing out of those cams if not making the car slower lol. You need work done to your block, and don't you need a tranny or some tranny components? I think you should focus on one thing at a time bud.
Not tryin to jack your thread but im debating whether to build my a3 or do a swap.
I was thinking to get JE 11.3:1 pistons, Eagle H-Beam rods, ACL race bearings, Brian Crower stage 3 cams, Z1 valves springs and retainers, A2 oil pump, and Kpro.I can get all this for about $2800 .What numbers can i expect? Or would it be smarter to get an A2?
2 diff sites i guess?
Ur 2 Slow 4 J
Feb 26, 2004 02:16 PM
jrthecow311
Feb 26, 2004 08:22 AM
