swaping da knuckles in my 91 crx si
I know they bolt right up. Question is will the si calipers bolt up still? I have to swap to da knuckles to use DSS 5.9 axles, other wise I wouldnt swap out the spindle arms...I am going to junkyard to pull the da knuckles, just want to know if I should pull the brakes with them?
I did a search and most info tells me I can use any brakes but nothing says keeping the original brakes...
thanks
thanks
thanks
thanks
i would use the da assembly together with the brakes and knuckles....i believe everthing on the da compare to the crx brake wise are bigger....so to save you the trip and trouble....do the knuckles and brakes...side note..coming from the yard and you taking the knuckles off...you might as well change the wheel bearings and pads.
ya everything is bigger on the da so i highly doubt the si caliper will work on it. if your gona be at the junk yard anywase just grab si caliper off a junk car and eyeball it to see if it will work.
redzcstandardhatch
Jul 28, 2003 04:32 AM
