kicker help
Old Feb 12, 2010 | 10:02 AM
boston71's Avatar
Default kicker help
Ok i hv a zx750.1 when i first hooked itup to kicker cvx 12 it hit hard now the problem is it will hit hard for a couple of sounds and then it seems as though its at one third power...............any help would be grateful
Old Feb 12, 2010 | 11:15 AM
fcm's Avatar
fcm
Old Fart
Default Re: kicker help
What type of fuse is in the amps power lead, [type not size]
What gauge is the amps power and ground leads?
How long is the amps ground lead and where and how is it grounded?
Is the CompXR a DVC 2 ohm or 4 ohm, and how are the VCs wired? 94
Old Feb 12, 2010 | 11:37 AM
boston71's Avatar
150 amp anl fuse 4gauge wire speaker is wired at 2 ohms .....ive had some pretty tight systems before 2 cerwin v-max w 4 component sets w 2 exl 400.4 and 2 exl 1200d.....im changing to all kicker 2 zx 750.1 2 350.4 2 15l5 and 4 component sets i got this amp off craigslist worked great when i first hooked it up went in house to get ready for work and when i left seemed as though sub was maybe at half power light is green never goes into protect i just checked my remote its fine im just stumped
Old Feb 12, 2010 | 04:27 PM
fcm's Avatar
fcm
Old Fart
It does not sound like a wiring issue, [but how about the ground] so that leaves only the amp itself, [it will not be the sub IMO]. 94
Old Feb 15, 2010 | 01:45 PM
ooopseyesharted's Avatar
like the last person said.
try another amp just to see if you have the same problem.
Old Feb 16, 2010 | 06:08 AM
ken9's Avatar
You mean songs or sound??
Old Feb 17, 2010 | 01:45 AM
Hondaobregon23's Avatar
Try another amp
Old Feb 28, 2010 | 10:05 AM
boston71's Avatar
so everyone knows it was the amp it would appear gains were to high and it did something to the input .....but thats ok ive decided to go all re audio anyone have any goods or bads about theirproducts
Old Feb 28, 2010 | 06:06 PM
idgf77's Avatar
ported enclosure for the R E.s...bangin...check your woofer phasing,is it a dvc sub?
Old Mar 1, 2010 | 05:15 AM
ken9's Avatar
Re audio are great products because I do own couples of their products..
Old Mar 1, 2010 | 11:24 AM
boston71's Avatar
yeah dvc 2 ohm w 1 0hm stable amp pushing 1000 watts custom made box by myself at 3.18 cubes the 3 which is required and the .18 to make up for speaker displacement ive also designed it so the port is removed and can be changed to different tuning freq in a matter of 30 min or so
NewtoCivics
Audio / Security / Video
12
Jan 11, 2012 04:28 AM
teggi
16
Jan 2, 2012 01:54 PM
Rizzen
14
Aug 23, 2008 12:30 PM
coneheadsracing
Apr 5, 2008 08:28 AM
Daniel_san
May 5, 2004 01:22 PM
