Rust issues?
anyone have any kind of rust issues with their RSX? specifically model year 2002? some of you might have seen that im looking into a 2002 type s, i havent seen the car yet, but i am told there is a minor rust area on the vehicle, but it would be repaired if i wanted to purchase it...i didnt think honda/acura had many rust issued besides the early 90's civic/accord...any input appreciated
im in the mid-west..southern illinois/st.louis,mo area...we usually get a couple good winter storms and i know salt is used during them...how severe can the rust get? re they as bad a the early 90's Hondas? I have a del sol currently and the rust is pretty bad and i wouldnt want the same problem
I'm not sure if the "newer" Hondas have the same rear-quarter panel rust issues as the 90-00 Hondas. But with any climate that has inclement weather, you can pretty much expect rust.
Be on the lookout for body damage or repairs, if it's rusting in an uncommon place.
We purchased a Honda CRV 2010 last december (only 4 months ago). Our car with less than 2 thousand miles on it has rusted brakes and many other parts. Dealor has agreed to replace brakes, but not the many other parts on the car that are rusted. We have a lot of hassles ahead of us under the lemon law. I would not recommend buying a Honda 2010, no matter what model.
I live in MI and my 2002 RSX has two tiny rust spots (about the size of a pencil eraser) on the roof and a little rust on the rear quarter. Any car will rust if you live in an area with salt... Also if the person is fixing the rust make sure its done right using ZR1 rust proofing because the rust will come right back if not fixed properly.
You replied to a post from 2 months ago to complain about a car that doesn't belong in this forum. Way to go.
Please click here:
https://honda-tech.com/login.php?do=...93051fa60efbf6
Should these parts be rusted after less than 4 months of use on a brand new car?
Passenger side rear brake rotor and caliper (driver's side is in the same condition)
Passenger side front brake rotor and caliper (driver's side is in the same condition)
Passenger side front tie rod end, hub/knuckle, CV axle (driver's side is in the same condition)
Passenger side front hub/knuckle, tie rod end bolt, control arm bolt, cv axle
Driver's side front hub/knuckle, tie rod end bolt, control arm bolt, cv axle
Catalytic converter mounting flange/beginning of B-Pipe exhaust component
Drive shaft flange (front)
rear differential and passenger side cv axle
rear differential and driver's side cv axle
drivers side rear hub/knuckle, rear lower control arm, cv axle, caliper
exhaust mounting flange (rear of car)where b-pipe meets the rear mufler
drivers side rear sway bar link hardware, end of sway bar
driver's side rear upper control arm
passenger side rear sway bar link hardware, end of sway bar
passenger side rear upper control arm
center driveshaft support bearing/bushing
intermediate shaft for passenger side cv axle
oil pan, transmission/differential case
passwenger side front sway bar link hardware
passenger side front knuckle, brake rotor
power steering pump
alternator
power steering pump
alternator
power steering pump
alternator
power steering pump
alternator
Not sure what sort of rust you're seeing on the alternator or power steering pump or trans since these have aluminum housings. I've only been building/working on cars for 11 years now so maybe I missed something.. Aluminum will corrode but rust? Please explain and maybe post pics.
headhunter
Jul 29, 2004 09:47 AM
for a Chi-towner!!!
