FS (feeler): B18c1 Swap
Picking up a EG w/ a B18c in it this weekend and that going to be parting the motor out, to put my sleeved High Comp H in it.
Here is what i know about the engine right now, it starting blowing smoke so previous owner had the motor rebuilt,
this is what i was told from previous owner, so will double check these things when i get the motor in my possession
-Low Comp Pistons (will verify what kind)
-Eagle Rods (will double check)
-all new gaskets, rings, bearings, fresh valve job, seals, etc.
-as far as i know head is all stock
-ACT 6puck clutch
-Trans feels clean, flowed in/out of all gears sitting there
right now car is boosted with a ebay turbo kit and wont stay running, will start and stutter than die, its running on a stock OBD2 GSR ECU, i believe its a timing issue, but there is not even 100 miles on the rebuild
Want $2000 OBO for the whole swap
Longblock, Trans, Linkage, Harness, and Mounts
can call me or txt (prefered) 317-727-6166
-ACT 6puck clutch
if its running on the stock obd2 ecu, that's the problem. if it ran, and doesn't now, it is prob blown up. you need a chipped obd1 ecu and a good tune to make that set up work. boost on stock map = fail
JdMhEaD
Jun 23, 2008 08:49 PM
help a fellow teg owner out
