1992 Civic Engine Light
Old Feb 12, 2010 | 03:29 AM
mahmi's Avatar
New User
Default 1992 Civic Engine Light
My 1992 Honda Civic seems like it drives weird on the highway.The engine light comes on everytime I brake to come off my daily highway drive (which is about a 30 minute ride straight). Then when I brake at the stop light, i hear it revying down and up a little with a little start. When I finally pull in the drive way and put the civic in park it almost seems as it want to shut off it gets so low. If I turn the car off and start it back off the engine light disappears. I had my distributor changed because it had been siting for a year and the battery died and had a problem starting up. I also did a full tune up. What could be going on?
Old Feb 12, 2010 | 07:15 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: 1992 Civic Engine Light
clean the iacv. idle air control valve. its right behind the intake manifold, between that and the firewall. unbolt it and clean it.
what is your CEL....
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Liam Malloy
Honda CR-V & Element
May 10, 2018 04:20 AM
Chadted
Honda Civic (2006 - 2015)
Jul 14, 2009 10:06 AM
EK45VTi
Mar 1, 2004 02:50 AM
CTR_EK9
Feb 14, 2003 11:01 AM
