Light Bulb #'s - 1991 Civic Hatch
So, I feel stupid even asking such a simple question, but I've searched and I can't quite find all the answers!
Headlight Low - 9006 (HB4) CONFIRMED!
Headlight High - 9005 (HB3) CONFIRMED!
Bumper Lights - 1156 (45CP) CONFIRMED!
Corner Light Front Socket- 194 (12V 5W Stanley) CONFIRMED!
Corner Light Rear Socket- 194 (12V 5W Stanley) CONFIRMED!
Thanks for your help!
Last edited by -dSoc- soccerwuedo5; Feb 12, 2010 at 12:15 PM. Reason: Information found!
pull out your corner light bulb. (they're all the same) take the bulb into kragen, vato zone, napa, ect. and compare it to the ones in the light bulb aisle, and you'll find your number.
I'll update this as I find things out today...because this is getting really annoying!
I tried searching through Majestic Honda and a couple impostor sites and found out the following, useless info:
Headlight Low - 9006 (HB4) CORRECT!
Headlight High - 9005 (HB3) CORRECT!
Bumper Lights - 45CP
Corner Light Front Socket- 12V 5W (Stanley)
Corner Light Rear Socket- 12V 5W (Stanley)
So, if anyone knows the actual numbers, lemme know...if not, I'll be doing some trial and error today until I know em and I'll post em up for the next guy
low beam 9006
high beam 9005
The bumper lights are 1156 (single contact)
Corner lights front and rear are 194
heres a link if you need to ID any more bulbs, btw something to keep in mind is that one bulb typically goes by many different numbers , this guide will most likely confuse you so beware. http://www.sylvania.com/ConsumerProd...RG-Results.htm
if you're still unsure pull the bulbs out when you go to the part store and match them up.
high beam 9005
Thanks for your input, Grog
ekinshuya
10
Mar 14, 2008 03:15 AM
dawrenn
Jun 6, 2005 03:09 PM
