O2 questions obd1 p30
Old Feb 11, 2010 | 07:34 PM
ByonSho's Avatar
Default O2 questions obd1 p30
So I got this 94 del sol running a (I believe) obd1 p30 ecu. It's a b16a with what I believe to be a jdm exhuast manifold. The Mani has 2 o2 sensors in it one single wire sensor unpluged, and a 4 wire sensor that is plugged in. The car use to be, a S, Aka d15. So I'm using the stock wiring harness and jumped the vtec.
I did very little of the wiring myself, everything I have done has fixed problems. But I can not find info on the o2, if it runs 1 or 2 sensors, and if they are 1 or 4 wires. I'm guessing they are a 4 wire single o2. And that's what I got and my cel blinks for that. I bought a new one have yet to install it.
So the question!
Is there 1 or 2 sensors, is/are they 1 or 4 wires? Should I swap the exhaust mani for a single sensor app. Or is the jdm one ok even though it only measusres 2 cylinders?
Thanks all in advance. I need my car smogged and I'm barrowing a car to drive 90 miles a day to Work and back so any help is appreciated.
Ps I did search this forum with no luck.
Old Feb 12, 2010 | 03:11 AM
ByonSho's Avatar
Default Re: O2 questions obd1 p30
Anybody got a obd1 b16 sol that can look at there's for me?
Old Feb 14, 2010 | 12:40 AM
StarkeySiR's Avatar
I have a 92 SiR b16a, it has a sensor at the bottom of the manifold, 4 Wire, two black one green and one white wire.
Thats the only oxygen sensor they have, you shouldnt have 2, some came with a Cat sensor which would put up a light on the dash if the cat overheats.
Old Feb 14, 2010 | 07:21 AM
Dc4iNtEgRa's Avatar
Is Partying at your House
You need a new header with a 02 bung at the end near the cat. You only need 1 sensor, and it's 4 wire.
Old Feb 14, 2010 | 09:01 AM
94civiccupew/b7's Avatar
^ correct. you have the wrong manifold. sounds like you have a obd2 manifold. one 4-wire o2 is all you need
Ls1 FD3s
Aug 27, 2007 06:44 PM
dougshatch
Jun 11, 2007 06:38 PM
russianswty
Dec 29, 2006 04:30 PM
davidcrx89
Mar 22, 2005 04:43 PM
civtegra_hybrid
Sep 14, 2004 01:15 AM
