LS/VTEV Build Need Help!!!
Alright im doing an lsvtec head and was wondering if i will have any valve clearance issues.
GSR Head
SKunk 2 Stage 2 tuner cams
supertech valves
skunk 2 valve springs and retainers
LS Block
81.5mm
Eagle H Beam Rods
Probe High comression pistons PN#11376-.50
was wondering if i will have valve issues... hopefully someone could help me out with this asap and let me know what would be the best head gasket to buy.
also could i use GSR ARP Head bolts or do i need LSVTEC head bolts???
GSR Head
supertech valves
LS Block
81.5mm
Eagle H Beam Rods
Well lets see here
GSR head bolts
LS or GSR head gasket. I chose the ls head gasket and my reasoning is because of this thread https://honda-tech.com/zerothread/1676914
When it comes to listening to others about there ptv and vtv on a similar setup I would do your own measurements. This is how https://honda-tech.com/zerothread/1891614
It's better to be safe than sorry.
You could have found this in the FAQ easily at the top.
GSR head bolts
