5 lug question
Old Feb 11, 2010 | 06:42 PM
k20rex's Avatar
Default 5 lug question
ok so i have some da knuckles and itr knuckle, i was wondering after i have the machine work done do i need to buy a caliper bracket? or will the itr caliper bolt up to the da knuckle?
Old Feb 12, 2010 | 07:19 AM
k20rex's Avatar
Default Re: 5 lug question
28 view and no answer dam
Old Feb 12, 2010 | 07:51 AM
88Hatchy's Avatar
As far as I know, the caliper brackets will bolt up to the DA knuckles. Do you have JDM or USDM ITR knuckles? The reason I ask is because they have different size bearings. If you have USDM ITR knuckles you should be able press the ITR hubs into the DA knuckles.
Old Feb 12, 2010 | 09:16 AM
k20rex's Avatar
i have usdm knuckles, do i need to buy a caliper bracket after i get the hub to fit? or will the caliper just bolt up to the da knuckle with no problems?
Old Feb 12, 2010 | 09:26 AM
dr_latino999's Avatar
You do realize that by converting to 5 lug you are limited in the choices of further brake upgrades. You should be able to just bolt on the caliper and go with the ITR Hub + ITR rotor + ITR caliper.
Old Feb 12, 2010 | 10:04 AM
k20rex's Avatar
i dont really think i will need to upgrade much more, maybe some dual piston calipers, its a street car not a race car, thanks for the head up
Old Feb 12, 2010 | 02:30 PM
DCRB's Avatar
brembo 12" brakes for a dc5 bolt right up to dc2r knuckles.... just have to run 16"s and the bleeder screws are opposite
C_Rock77
Suspension & Brakes
Sep 22, 2013 05:31 PM
homey dont play dat
Mar 18, 2010 08:04 PM
rickkane
Suspension & Brakes
May 23, 2009 11:33 AM
Lissav
29
Mar 17, 2006 11:07 AM
MOVE OVER
Jun 29, 2005 07:22 PM
