obd2 motor into obd1 chassis...searched...
in order to run an obd2 motor in an obd1 chassis whats all needed from the obd2 motor..
just harness and ecu...o and if ur gonna respnd and says somethin regarding there is a thread
already...just put the link in ur reply please thanks!!
i kno i mentioned i was gettin a b18 swap, but till i am ready to put tht in and do it right
i wanna swap in a y8 motor from my buddy which i got fro free...he has the ecu, complete
motor and wiring harness...is that all i need or can i use a z6 ecu/harness on the y8?
btw car is a 93 del sol si
obd2 engines have more evap bullcrap on the intake manifold. they all have knock sensors (i'm pretty sure), and they all have crankshaft fluctuation (ckf) sensors on the oil pump.
vtec engines have the knock sensors and the CKP crankshaft position sensor, because in obd2 its not ran from the dizzy like obd1
the obd2 dizzy does have the ckp in it, just like obd1. the crankshaft fluctuation (ckf) sensor however is only present on obd2 engines, and they are 2 completely different sensors
To the OP, the easiest way to do this swap is to use the harness from a '96 - '97 Del Sol Si, or a '96 - '99 Integra LS/ITR, you will need to wire in vtec if using an LS harness.
go to the hybrid section. There is a huge article all bout this. All I remember off hand is that you will need to rewire the iacv. Dont' worry bout the crank sensor on the oil pump cause your obd-1 ecu wont read it. It's not a very hard swap at all since it's going into an obd-1 car.
You don't need to waste your time getting other harnesses. Just use the stock del sol one.
