Integra Caliper Civic Bracket
I don't have time right now to search through the massive amounts of info on brake swaps. I just need this questions answered.
I know they fit together, but Is it ok to bolt a 94-01 Integra Caliper to the 92-95 civic Caliper bracket??
I want to do this so I don't have to buy another set of brake pads since the civic pads wont fit into the integra bracket.
Yeah I know but since that's the only difference I'm thinking it will work.
The reason I ask this is because my drivers side caliper piston will not compress. And I happen to have some integra calipers laying in my garage. I bolted it up and I don't see any problems. Also this is on a 93 EX so they both cars have the same size rotors.
it wont work if u have a dx(canada)... the knockle is different so you wont be able to put the 94integ caliper brace on. and the rotors are much larger than the dx(cnd) so the brace wont make it to the holes in the knockle with the rotor on the hub.
well, I had the caliper bolted up and every thing looked fine. But I bit the bullet and got integra pads so I could use both Integra calipers and caliper brackets.
Thanks
Thanks
I just purchased front knucles and rear trailing arms from a 94 RS!!!! I have a 97 EX coupe Non abs. Will the ebrake cables work just fine or do i need to get the 99-00 SI ebrake cables? also the fron calipers are they the same? What SS brake lines should i be purchasing. And also Last question. I have a 98+ spec ITR 1inch Brake Booster/MC laying around. Do i need to swap this for my stock 15/16 which is the same as the Si, I know i need the 99-00 Prop valve. PLEASE HELP GUYS!!!!! THANKS IN ADVANCE
tekstyle
Dec 8, 2007 03:32 PM
philly-O
Apr 21, 2003 09:15 AM
