Suspension & Brakes Theory, alignment, spring rates....
integra MC on ek BB
Old Feb 10, 2010 | 07:47 PM
adam00's Avatar
Default integra MC on ek BB
Can i put an integra master cylinder on a ek brake booster?
Old Feb 10, 2010 | 09:35 PM
kommon_sense's Avatar
Default Re: integra MC on ek BB
depends on what year integra and what year ek. I know that the 98-01 integra mc will bolt up to 96-98 ek's.
*HOWEVER*, you shouldn't do it without swapping the booster as well. The reason is you can't properly adjust the pushrod to get proper pedal travel.
Old Feb 10, 2010 | 09:36 PM
ntoxicatedtigah's Avatar
same question.... so the 94-97 integra's have different master cylinder than the 98-01 integra?
Old Feb 11, 2010 | 05:32 AM
unusual71's Avatar
since we're on the topic
I just picked up a 15/16ths MC what sort of booster is for a MC
that mounts like this " / " the angle is not quite that extreme but
i dont know how else to describe it. if i mounted it to my Ek
booster (which has 2 studs parallel with the ground) then it will
sit at a big angle which wouldnt really work out so im just wondering
what sort of booster im looking for.
Old Feb 12, 2010 | 12:07 PM
ok i just researched man. and i also have an ek. for a bigger booster to work. u need it from 98-01 integra's. nothing below. ls will be 15/16th and gsr or type r will be 1"
EKSedAndy
15
May 2, 2010 09:39 PM
1sikhatch
Nov 19, 2009 06:02 PM
hialeahzbg
Jul 17, 2005 06:01 PM
SpoolinEK
May 10, 2004 11:26 AM
