Anyone put an EPS system in their accord?
Old Feb 10, 2010 | 05:37 PM
starboy2nv's Avatar
Default Anyone put an EPS system in their accord?
as the title says.
I've seen euro accords (sir i believe) comes with this unit (electronic power steering), anyone try putting it in their accord?
discuss!
Old Feb 10, 2010 | 05:54 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Anyone put an EPS system in their accord?
I"m assuming you're wanting to do this to remove the minimal mount of parasitic draw the pump has on the motor?
It's not worth it. If your concern is getting rid of the pump then just remove it entirely.
And by remove it entirely I mean keep the rack and loop it with a vent - there are FAQs on the topic
Old Feb 10, 2010 | 06:04 PM
starboy2nv's Avatar
actually, i wanted to clean up my engine bay since its painted (getting redone: shaved) and tucked...
i had assumed that something could have been done, but guess not. i really dont want to go the route where i remove the pump and having to it harder to turn...
any ideas? tips?
Old Feb 10, 2010 | 06:06 PM
If you're wanting to do a shaved bay then your best bet is to loop it and grow some muscles.
The only difficulty is when you're going slow in a parking lot trying to maneuver. It's not bad elsewhere. You can search the forums and read up on it.
Old Feb 10, 2010 | 06:13 PM
starboy2nv's Avatar
i see... i already went the route of looping the rack and it wasnt my cup of tea since i do alot of city driving...
Old Feb 10, 2010 | 06:33 PM
tamadrummer1120's Avatar
Well, I doubt there is even room enough under our dash to fit an EPS, because if you have seen one of those, it is like a huge starter under there, not to mention the wiring headache that entails. Even then you still would need to loop the rack and still drain the fluid and change it at whatever the interval guys are doing at that have it looped. So you need to decide what is more important. Convenience of driving in the city, or having a perfectly good looking tucked bay.
Old Feb 10, 2010 | 09:57 PM
GlassJAw's Avatar
I have a CL1 Euro R Accord with factory EPS fitted...... I can definitely tell you it's not worth the trouble trying to get it to work in your car. You will have to modify the Headers to work with it for starters, it has it's own seperate ECU (which gives allot of trouble) a 3 way switch on the dash which makes the steering harder or softer and it's also wired into the OBD2 Port connector to flash Problem codes through a CEL type light in the dash. The steering rack / unit itself is huge -hence the need to modify the headers and would be easily seen at the back of the engine compartment.
Old Feb 11, 2010 | 09:38 AM
starboy2nv's Avatar
when you have time, is it possible to take some pics?
Old Feb 11, 2010 | 09:04 PM
GlassJAw's Avatar
I had another thought...... You may have to try retrofit a S2000 / EP3 one if you're really adimant on goin this route. CF4 Torneo / Accords & CL1 Euro R Torneo / Accords are only Right Hook...... unless you car is right hook you wont get the steering column shaft to mate up to the steering rack.
Old Feb 12, 2010 | 05:50 AM
starboy2nv's Avatar
thanks glass.. my back up option was to do exactly what you said... luckly my shop has both cars in and the owners wont mind...
looking at the oem parts on majestic's site, i dont see a starter that tama mentions...
going back to the cf4 and cl1, stupid question- can i just flip it?
Old Feb 12, 2010 | 10:13 AM
no, no, no, you misinterpreted what I said. It "Looks" like a starter under the dash. Meaning it is pretty big, and very difficult to fit under an accord dash.
Old Feb 12, 2010 | 02:03 PM
starboy2nv's Avatar
tama, i think we are talking about 2 different things here.
i think your talking about the mr2 pump?
im talking/thinking about adapting the s2k/ep3 eps to the cl/accord
Old Feb 12, 2010 | 04:34 PM
no i am talking about in general, electric power steering pumps are very large. and they look like a huge starter haha. not talking about a specific one.
Old Feb 19, 2010 | 12:29 PM
starboy2nv's Avatar
tama: ive had a look at a 06 si unit. yup.. **** looks like a task...
but im determined. will post back when i have the unit off the car.
Old Feb 19, 2010 | 12:35 PM
cstone's Avatar
i wish you the best of luck! that sounds like quite a task. if its not too much trouble, a write-up would be awesome. if not thats deffinatly understandable.
i will deffinatly be looking forward to hearing your results. and expect at least a shot of the engine bay when you are done
Old Feb 19, 2010 | 01:13 PM
well, to be honest, the only kind of EPS unit that would be worth it for you is one that goes under a dash, just because if you are doing a wire tuck, having that in the engine bay would be the complete opposite of what you want. having said that......I do believe you may have to move some of the control boxes and such under the dash to another location. If you are getting rid of a/c and all maybe over to the right side? Or something like that.
Old Feb 20, 2010 | 01:39 PM
starboy2nv's Avatar
tama: im not to sure on which setup can go under the dash that your talking about. can you explain?
I will be referring to this guide made for the rsx. (yes i know totally different car/setup, but atleast i can get some ideas while tackling this swap)
http://willbelayforfood.com/RSX/RSXM...PS_Install.htm
i am keeping the a/c and getting custom lines made... that should be one of the next updates i have...
fyi: i have a 97 acura cl and heres my update thread on acurazine:
http://cl.acurazine.com/forums/showthread.php?t=494169
Old May 31, 2010 | 10:15 PM
sadam-insane's Avatar
that looks very promising has anyone tried this as yet?
Old Aug 3, 2010 | 11:35 AM
Why would you go with the RSX set Up? I would attemp the MR2 EPS set up and and adda ABS box instead of changing the whole rack.
Old Aug 3, 2010 | 11:42 AM
robinmarkk's Avatar
Yes, I have already Electronic Power Steering system in my Honda accord Euro model. It is such nice system. Electronic power Steering system is depend on your car speed and how much you turn the wheel. It is a good feel on road.
mem94043
Mar 13, 2011 07:16 PM
Benjamin100
Dec 24, 2009 01:33 AM
Kaliona
Classic Hondas
Aug 21, 2009 04:16 PM
bigfigman
Jul 8, 2007 10:27 AM
accord478
Apr 10, 2007 10:44 AM
