B16 Turbo
Old Feb 10, 2010 | 05:30 PM
Mref813's Avatar
Default B16 Turbo
hey whats good yo... i just put my turbo on my EG hatch... its a bone stock motor so idk how many pounds of boost i could push in till i get the tune
Old Feb 10, 2010 | 06:29 PM
mrharmonic's Avatar
Default Re: B16 Turbo
no more then 8 bro reson why no one has alredy commented is becase use the search engine bro but good luck on your build
Old Feb 10, 2010 | 06:33 PM
gsreg607's Avatar
yes^^^
Old Feb 10, 2010 | 06:38 PM
iamthefollower's Avatar
What turbo are you using? What is your setup, injectors, IC piping and such, turbo specs, trim size. What power goal are you wanting? These are the things that can help us, help you. If you can give us this information we can probably be able to help you more, the size of the turbo and such will determine how much psi you can put on the motor, might be 8psi with a big turbo and could also be 14psi on a small turbo to get to your power goal..
Old Feb 10, 2010 | 06:39 PM
Speed_1's Avatar
edit hopeless. dont put any boost on your car without a tune unless you like to blow motors
Old Feb 10, 2010 | 09:38 PM
WavyIntegra's Avatar
More info could be helpful..
I' was always under the assumption that you shouldn't run Turbo without a Tune. And if you're going to be an ******* and do it anyway..IF You're on stock internals (And there are 400hp B16's around here on Stock Internals and boost), you shouldn't run more then 6 without an intercooler (91 Octane Only) and if you're running an intercooler, no Tune anywhere between 10-15 is Prime.
Now this isn't law...i'm just going off what I've seen and experienced personally. My buddy, like many ********, is currently running a B16, No Tune, Intercooler, Full Set up, stock internals @ 13psi's and it's ran FINE for going on 10 months now.
Ultimately, you should do more reading...and do it right. Tune it, Intercool it, and Boost it and you can strive for some stratospheric numbers with your stock internals.
Old Feb 10, 2010 | 09:43 PM
forcefedferio's Avatar
there are only 3 posts in here you should listen to, 2 of them above and mine right here.
Old Feb 10, 2010 | 10:06 PM
Schister66's Avatar
Man U FTW
*Slams head on desk....20-30 minutes pass....consciousness slowly returns......*
After a while, it gets really old trying to answer the same questions...especially when the same 'experts' get there before you. OP: You need to check the Forced Induction forum. The Model Specific forums are not the places to ask for advice on this sort of issue. You tend to get answers like "no moAr then 8lbs brah" which really isn't an answer of any kind. I think a few of the guys above me have given you some insight. The rest is on you. Search the FI FAQ and the forum...you'll find answers if you look.
Old Feb 11, 2010 | 02:36 AM
Mref813's Avatar
the turbo is a t3 t4 n im using 550 injec i know i have to get it tune but i just move here to diz city n i dont know that many shops the tune that y im askin intill i could find a good shop cuz if i was to b back home it would b diferent n thanks guys for the help
LS/V-T
Jan 16, 2011 09:37 PM
B16Civic93
Feb 19, 2005 10:24 AM
Mr.c
18
Jul 8, 2004 02:09 PM
JDMcivic18
Dec 3, 2002 06:53 PM
