WHAT IS THIS CONNECTOR FOR?!
Old Feb 10, 2010 | 04:16 PM
mwaedow's Avatar
Icon2 WHAT IS THIS CONNECTOR FOR?!
I have this gray 18 pin connector by the driver's kick panel on my Civic. I can't find anywhere to plug it in. It's linked to a relay on the left side of the dash, and if I pull the relay, the car won't start. There's a constant hot wire on this plug, and I would like to know what it's for. It's a swapped harness from a 2000 Civic Si, in a 96 LX. I don't have power locks or a power moonroof. The relay it's attached to is one of two mounted together on the dash. Anyone know?
Old Feb 10, 2010 | 06:46 PM
mrharmonic's Avatar
Default Re: WHAT IS THIS CONNECTOR FOR?!
take a pic of it kinda vage to tell us the pin connecter and not see a pic of it snap it and put it up to steer you the right way
Old Feb 10, 2010 | 06:49 PM
zemakix's Avatar
can you swap a obd2b harness into a obd2a car?
Old Feb 10, 2010 | 07:06 PM
mwaedow's Avatar
I swapped a B16a2 from an '00 SI, along with the dashboard and wiring harness. everything is obd2b now. I'm just having these lingering issues with shorts and things that were altered on the harness for an alarm/remote start. cut wires, annoying stuff. I think I'm just freaked out that there's extra stuff on the SI harness that my sedan doesn't have.
Old Feb 10, 2010 | 07:09 PM
project evO's Avatar
you sure its not ur diagnosis cable? cause i just took my em2 to a shop and theres always that cable there and thats what they use for engine light check ups and crap like that. i dunno i need to see a pic of it
Old Feb 10, 2010 | 08:51 PM
mwaedow's Avatar
no, definitely not the DLC, This one has 17 wires running to it. It runs off the same part of the loom as the blue cruise control connector.
Old Feb 10, 2010 | 09:00 PM
jasoncanseeoh's Avatar
Visuals of this wire would definitely get you better responses. I promise.
andrew781
May 27, 2015 08:20 AM
Dalamar
10
May 11, 2012 05:09 PM
duckmanEG
Mar 21, 2007 12:52 PM
sled
Feb 12, 2006 09:05 AM
type r 01-1063
Dec 10, 2003 02:00 PM
