Cluster Lights / Spark
Old Feb 10, 2010 | 01:42 PM
toolbox21's Avatar
Default Cluster Lights / Spark
Yesterday Everything Worked Fine. The Annoying Beeping Sound When The doors Open And Key In Ignition, And When You Turn It On #2 All The Lights Came On Including Lights "Including Check Engine" Flashed And Went Off Like Normal Except Battery Light Because That Stays On Until Car Is On. But Now When I Turn It On #2 No Lights Come On And Flash, The Only Light That Come On Is The Batt. Light, Ever Since The Lights ON The Cluster Stopped Working Im Getting No Spark, And Ideas Im Lost At This Point And Info Will Be Appreciated
Old Feb 11, 2010 | 04:16 AM
toolbox21's Avatar
Default Re: Cluster Lights / Spark
Anyone, This Sh*ts Weird And has Me Lost LoL
Old Feb 11, 2010 | 07:12 AM
ef-hatchcrap's Avatar
Ok after some long research I found that the fuse for the reverse lights was not the right amperage. replaced it with the correct one and now everything works except for the injectors are not spraying.
They are obd-1 with the resistor box still hooked up. Should I take the resistor box out and then try again?
JJGL-EF90
Feb 21, 2011 11:37 AM
EusebioSam19
Oct 24, 2010 08:20 PM
mickeey
Mar 11, 2009 07:18 AM
DoWnfall
Nov 9, 2008 08:33 AM
aojtin
Nov 25, 2007 06:36 PM
