98 accord synchronizing piston spring
Old Feb 9, 2010 | 06:25 PM
2accrds's Avatar
Default 98 accord synchronizing piston spring
I need a synchronizing piston spring for my 98 accord 4cyl F23. Its the little spring located inside the rocker arm. Anyone know where to get one, or have one I could buy?
Old Feb 9, 2010 | 07:06 PM
slomofo's Avatar
GDD Member
Default Re: 98 accord synchronizing piston spring
There's no spring in the rocker arm, what are you talking about? Post a picture please.
Are you talking about the big spring that runs through the center of all the rocker arms?
Old Feb 9, 2010 | 07:16 PM
tamadrummer1120's Avatar
Assuming your engine is the VTEC engine.....
http://www.hondaautomotiveparts.com/...ARM+%28VTEC%29
number 4 is the rocker spring, and 8 and 9 is the valve spring.
I am assuming you are talking about 4.
Old Feb 9, 2010 | 07:22 PM
slomofo's Avatar
GDD Member
That's the same one I just asked about.
Old Feb 9, 2010 | 07:26 PM
2accrds's Avatar
No, the spring I am referring to is inside the assembly and not available separately from the dealer. It is located between the timing piston and synchronizing piston A.
Old Feb 9, 2010 | 07:35 PM
slomofo's Avatar
GDD Member
Ahhh, the spring that pushes the pins out when VTEC engages.
Nobody sells those, you have to take apart a head in a junkyard to get them.
Old Feb 9, 2010 | 07:44 PM
wait check out the link i provided on majestic, what about number 1?
That is the whole rocker assembly, if you only need one fixed, you could replace the whole thing with that? I dunno, that looks like the whole thing.
Old Feb 9, 2010 | 08:26 PM
2accrds's Avatar
Yes, it would include the part I need. But I don't want to spend $200 for a spring.
Old Feb 9, 2010 | 10:40 PM
AFAccord's Avatar
I've got a few extra valvetrains, but not sure if they're in my garage or in storage. I'll take a look for you this weekend. If I find one, you can just cover shipping.
Old Feb 10, 2010 | 05:50 AM
2accrds's Avatar
That would be awesome, send me a PM if you find any.
bopbop93030
Suspension & Brakes
Nov 24, 2008 11:55 AM
invisible
Suspension & Brakes
Jul 27, 2007 04:05 AM
Blizzard
Feb 22, 2005 06:21 PM
