Rods / Bearings / HELP!!!!!
Old Feb 9, 2010 | 04:55 PM
Mutiny1's Avatar
Default Rods / Bearings / HELP!!!!!
I have a B18b1 with weisco pistons and Eagle rods. I bought ACL bearings and was told to torque the eagle rods to 43 flbs. when i do this i can barly spin the crank with a 2foot breaker bar... obviously its too tight. they are standard size ACL bearings. I hear that Eagle rods are tighter then OEM rods. What size bearing do i need for this to work? i dont think 43flbs is to much so im guessing its just the bearings.
has anyone else had this problem with Eagle rods and ACL bearings? What do we do?
Im gonna call my machine shop tomorrow and probably end up taking it in there..but was hoping to do all the work myself, I am a certified tech..just not a pro engine builder.
Old Feb 9, 2010 | 05:03 PM
IN VTEC's Avatar
Default Re: Rods / Bearings / HELP!!!!!
Measure the clearance. 43 lb*ft of torque should be specified with a lubricant weight, whether it be ARP moly, 30W oil, etc.
Also, what's the breakaway torque on the crankshaft by itself? You should be able to spin the crank at the snout by hand.
Old Feb 9, 2010 | 05:07 PM
Mutiny1's Avatar
i used the ARP moly. and the break away torque when the rods are torqued down id say is over 80+ which is just nuts. i just have a basic micrometer so im thinking this might be outta my ablitys to do at this point
Old Feb 9, 2010 | 05:19 PM
4piston's Avatar
Yeah that isn't right. Take it to someone.
Old Feb 11, 2010 | 11:30 PM
Shimakid12's Avatar
Was everything measured/clearances checked before choosing the bearing sizes? The crank should definitely spin freely.
Old Feb 12, 2010 | 03:16 AM
Mutiny1's Avatar
Fixed it..im a retard and switched 2 rod caps on the eagle rods.
Old Feb 12, 2010 | 05:59 AM
95 integra's Avatar
Certified tech you say.....doesnt count for much now-a-days.
Old Feb 13, 2010 | 02:38 PM
Mutiny1's Avatar
Jeeze thanks buddy, but at least i found my mistake and fixed it without causing any damages.
currently im a tech at Chevy but i wish to work for Acura in the future.
Old Feb 13, 2010 | 02:44 PM
xzodiackillerx's Avatar
eagle rods should be torqued to these specs..
http://www.eaglerod.com/index.php?op...d=24&Itemid=25
. it depends on the bolts but mine were 28
Old Feb 13, 2010 | 04:26 PM
PyroProblem's Avatar
yeah, if you used a 3/8ths socket to torque the head, you have 5/16th rod bolts. The torque spec for these is 28 ft/lbs, not 40 ft/lbs.
ForceFed_DA
Feb 22, 2007 08:39 PM
minivan81
Apr 5, 2004 04:38 AM
nicklk
Feb 9, 2004 06:41 PM
crx1856
Sep 20, 2003 01:15 AM
Killer_B
Jun 25, 2003 11:06 AM
