Steering Wheel, what size, 320 350?
I'm going to be getting a MOMO Monte Carlo steering wheel and I was wondering what a good size is for our cars? It comes in 320mm and 350mm. Is there anything else I need to know about installing a aftermarket wheel? I know I need a $75 hub but what about wiring and stuff. I have to loose the clock spring so I'll have to shut off the turning signals by hand right? Please guys, just tell me everything I need to know cause there wasnt alot when I searched.
Wheel size is personal preference, I'd go with a larger wheel, but most would go smaller; installation is pretty straightforward.
- Disconnect battery.
- Remove 2 plastic covers on sides of steering wheel.
- Remove 2 torx screws which hold airbag on.
- Remove airbag, unplug connectors.
- Remove steering wheel nut.
- Remove airbag clockspring & unplug yellow harnesses.
- Wire up new horn.
- Install new hub.
- Install new wheel w/horn.
- Remove instrument cluster and unplug yellow connector from back.
- Put gauge cluster back in.
- Fail safety inspection for not having an airbag.
- Get a ticket whenever Highway Patrol stops you and notices the missing airbag.
- Get in an accident & die because the airbag is missing.
- From heaven: Watch your widow struggle to pay the bills because life insurance didn't pay out due to the missing airbag.
- Wire up new horn.
- Install new hub.
DC5mike
Jan 12, 2008 08:15 PM
ek9tl
Feb 22, 2007 10:34 AM
b18_crx
Jun 19, 2006 09:19 AM
