crx wasting alot of gas
hey guys i have a 1991 honda crx si and im having a little trouble will the gas, i filled up my tank and drove about 56 miles and i already have a little less then half a tank. i dont know what my problem could be?car is running really rich because you can see and smell the gas from the exhaust pipe.car doesnt have a 02 sensor dont know if it could be that? and also owner before toke off all the vaccum system with the map?Thats problem one, problem two is when i rev up the motor slowly at a stop, car starts breaking up, but only if you rev it up slowly, kinda sounds like a two step but its not?
So, if I've been able to correctly decipher what you've written, you have no O2 sensor and a disconnected map sensor/messed up vacuum system?
These two problems would be a very good place to start. Typically when you know about a problem with your car AND it isn't running properly, it's a good idea to fix the known problem(s). I would get a stock vacuum diagram, fix your vacuum lines and then connect your O2 sensor. I imagine that you have a header without an O2 bung (this is the only option that makes sense anyway) but even if you're too cheap to get one welded in, I suspect that fixing the vacuum system will be a big improvement.
Edit: Oh, and some of the responses are unreal... sparkplugs because you're running too rich? Distributer? Larger fuel injectors??? Come on...
Last edited by Black4thgenEF; Feb 9, 2010 at 02:35 PM. Reason: Edited for reasoning
