Transmission & Drivetrain Gearboxes, Differentials, Clutches
dropping the trans
Old Feb 8, 2010 | 04:05 PM
animeFrank's Avatar
Default dropping the trans
So i asked this in the wrong section so here it goes.
So hi guys im currently in the process of changing my clutch in the snow and i ran into the bitch pin and i was wondering if i could drop the transmission alittle bit with the linkage still attached and change the clutch or would i have to remove the linkage from the end and then drop it?
Old Feb 8, 2010 | 04:32 PM
animeFrank's Avatar
Default Re: dropping the trans
any advice?
Old Feb 8, 2010 | 05:22 PM
94EG8's Avatar
Seagull Management
You can unbolt the other end of the linkage.
Old Feb 8, 2010 | 06:00 PM
JDM-sol 89's Avatar
This is true. Just un-screw your shift **** and un-bolt the two 12mm bolts holding the shift linkage to the chassis.
8Gomer9
Aug 21, 2009 09:46 AM
BorderM3
Mar 18, 2003 09:25 AM
made in JAPAN
Jan 31, 2003 08:22 PM
