Flywheel marking
Old Feb 8, 2010 | 10:39 AM
TheOdd001's Avatar
Default Flywheel marking
I have a fidanza 8lb flywheel and it doesn't come marked... as in timing marks. I was wondering once installed and having at TDC, can the TDC be marked for 0 deg... and then go, lets say 16 deg, from center of the flywheel from the TDC mark for the ignition timing mark? If so do you go clockwise or counter clockwise from your TDC mark?
Old Feb 8, 2010 | 02:12 PM
delsolproblems's Avatar
Default Re: Flywheel marking
I think the timing marks you're referring to are on the crankshaft pulley, not the flywheel.
Old Feb 8, 2010 | 04:30 PM
TheOdd001's Avatar
I know on my H23 theres a little rubber stopper that you can remove and it exposes the flywheel teeth and theres a pointer to indicate and adjust ignition timing... The marks are on the flywheel.
Old Feb 9, 2010 | 02:05 PM
90blackcrx's Avatar
If you look close it should be on there, its a small little dot, all the fidanza ones we've installed had the dot ( for the h22 / h23 )
Old Feb 10, 2010 | 01:05 AM
TheOdd001's Avatar
Hmmm okay thanks I'll take a look. Is this dot for TDC 16deg?
Old Feb 10, 2010 | 07:54 AM
90blackcrx's Avatar
The dot represents tdc
Old Feb 10, 2010 | 10:40 AM
riceburner700's Avatar
just sit it on top of your stocker and mark the timing marks on the new flywheel
meanshyguy
Aug 24, 2009 03:43 PM
deucedeuceEK
Jan 2, 2007 08:52 AM
BoostedH23a1
Dec 15, 2003 01:48 PM
preluda92
Oct 24, 2003 09:41 AM
H23ludedude
Feb 20, 2003 05:23 AM
