Fuel Pump
Old Feb 8, 2010 | 09:49 AM
ef-hatchcrap's Avatar
Default Fuel Pump
Just picked up a crx, replaced the fuel pump with a walbro i had laying around i put everything back together as it was, the fuel pump wont prime so i jumped it and it kicks on but not pumping fuel to the motor. the pump i used came out of a running crx, any ideas
Old Feb 8, 2010 | 09:57 AM
Black4thgenEF's Avatar
Default Re: Fuel Pump
Was the fuel pump not working when you got the car?
Old Feb 8, 2010 | 10:04 AM
Dc4iNtEgRa's Avatar
Is Partying at your House
If it didn't work when you got the car, check the engine grounds. I forgot the ground on the thermostat housing after my swap, and the fuel pump wouldn't prime. If they are fine, then I would guess main relay.
Old Feb 8, 2010 | 11:46 AM
There was no fuel pump in the car. replaced with a walbro its pumping but not to the motor...gonna put some more gas in it and see if it is just low.
Its my brothers crx hes the one that posted this on my account
Old Feb 8, 2010 | 01:41 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Check fuse #14 under the dash labeled "alternator,solenoid"
Top row second from the left...
Old Feb 8, 2010 | 05:44 PM
All the fuses are good im gonna mess with it more tomorrow
Old Feb 12, 2010 | 05:09 PM
90 si's Avatar
New User
just wire up the fuel pump directly to a new relay and set up the relay to turn on for key on
Old Feb 13, 2010 | 12:02 AM
DAtegLs's Avatar
thats what my crx is doing. pump kicks on but wont pump fuel. even after wiring it straight to a battery. im almost positive my problem is a bad connection in the tank though. make sure the ground and power wires to the pump in the tank are tight....that might be it.
hatchBK4life
Aug 2, 2010 05:11 PM
KansasKev
10
Jun 1, 2007 12:36 PM
GDM S2K
Honda S2000
Jan 8, 2007 01:30 PM
progressivedrunk
Oct 19, 2003 05:45 PM
