96 ITR ball joint replacement?
Old Feb 7, 2010 | 10:26 PM
Chrisfrom1986's Avatar
Default 96 ITR ball joint replacement?
Will a GSR ball joint work?
Also, the wheels bearings from a GSR work in the stock ITR hubs or they need to be used with the Civic hybrid electric?
Old Feb 7, 2010 | 10:30 PM
b18cKoupe's Avatar
Default Re: 96 ITR ball joint replacement?
this is an educated guess but the ball joints should work, I don't think the gsr wheel bearing will work in the stock itr setup though.
Old Feb 7, 2010 | 11:14 PM
TheAsian's Avatar
I looked into the wheel bearing a while back and no they wont work. I dont remember why but they wont work.
Ball joints im not sure. You could always cross referance the parts on the dealer site and see if they come up as the same P/N
Old Feb 8, 2010 | 03:43 AM
BlueIntegraBoy's Avatar
You guys are supplying wrong info. The balljoints and wheel bearings from a Civic would even work, so yes 'GSR' parts will work.
I don't have an Acura dealership on my island, so I went to the Honda dealership and bought Civic wheel bearings and ball joints for my R.
Old Feb 8, 2010 | 08:59 AM
TheAsian's Avatar
Hey I tried to use a GSR Bearing and it wouldnt work for me. My hub was to big to accept the bearing.
Ball joint idk. Im just providing from my personal experiance
Old Feb 8, 2010 | 01:20 PM
racebum's Avatar
jdm hubs? i know the later ones are made for the big axles. unsure if it effects hub sizing since i have never played with one. chime back if you can.
Majlo's Avatar
Hello.
I come from Poland. I see your forum very often, but without registration. I have been drawing much interesting knowledge. I registered, because I would like please you about some help. I’m thinking about our a national competition of the best fun club of Honda.
If you want vote, please, click a below link/reference:
http://fanklubmoto2010.auto-swiat.pl...c-klub-polska/
There isn’t a spam!!!
I don’t know English enough, so I’m sorry for mistakes, and if my advertisement has put in a bad place.
Please, don’t validate my advertisement so fast.
Thanks for your help!
Kind regards for everyone owners of Honda! ?
Old Feb 8, 2010 | 02:21 PM
highroller54's Avatar
are we talking front wheel bearings or rear? 1996 4 lug 4x114.3 wheel bearings are 94-01 teggy, any model, ls, gsr, type r. Same for the lower ball joints, if your talking rear hub bearings I dont know, I have heard hybrid hubs work but I have no first hand experiance. If were are talking front bearings for a jdm itr 5 lug then 97-01 crv, ball joints are the same as the 4 lug stuff.
Old Feb 9, 2010 | 04:16 PM
Dogginator's Avatar
Daisy... Daisy...
When in doubt, look at the part numbers at a site like this:
www.hondapartsunlimited.com
They are the same in this case. Keep in mind that you will suffer a minimum of a 10whp penalty for using a part found on a non-R.
Old Feb 9, 2010 | 04:19 PM
you can look up a jdm 1996 spec itr on a honda site?
Old Feb 9, 2010 | 04:36 PM
Dogginator's Avatar
Daisy... Daisy...
I suppose not. They are still the same. The difference with the 96 was the hubs and brake rotors. The calipers are the same as a gen 3 GSR.
Old Feb 9, 2010 | 05:54 PM
Rus1an's Avatar
I think the ball joints/wheel bearings from Integra is all the same 94-01 but the wheel bearing is diffrent if you have the JDM ITR 5 lug. So you would need like CRV wheel bearing for the bigger hubs.
Not %100 sure...
Old Feb 9, 2010 | 06:39 PM
The front caliper bracket is not the same.
Old Feb 21, 2010 | 01:16 PM
Thanks for all your replies guys, Ill be picking up some GSR ball joints and wheel bearings for the front 96 ITR spindles and will post again when I get them installed.
Old Mar 14, 2010 | 10:32 PM
teg97's Avatar
please do as I need to do this to mine also
Old Mar 14, 2011 | 10:03 PM
hYbRid_Eg6's Avatar
so the 94-01 integra gsr or any model integra ball joints work for the jdm 98+ 5 lug?
Old Mar 15, 2011 | 10:04 AM
hYbRid_Eg6's Avatar
Anyone?
Old May 12, 2011 | 12:10 PM
I don't know about that this isn't what this thread is about. There's a thread here that I believe says the crv front spindle is the same part number as the 36mm itr hub so you may want to try using those.
As for the 96 4x114.3 itr hubs I used a gsr ball joint and wheel bearing with no problem.
Humphrizzle
Transmission & Drivetrain
Oct 21, 2013 06:58 AM
NoLeftTurn
Sep 9, 2009 05:11 PM
Willz
Mar 26, 2007 07:05 PM
deadly_sleeper
Oct 25, 2005 11:42 PM
madsack
Apr 15, 2004 07:20 PM
