jrsc install
Old Feb 7, 2010 | 08:50 PM
blackk20dc5's Avatar
Default jrsc install
So i have a couple of questions.
I installed a jrsc this past weekend and when I put my battery back in the car and tried to turn it on there was no power. I tried to lock and unlock the car and that would not even work. I checked the fuses but they seemed to be okay. Any ideas?
Also for those who have install it, did you have any clearence issues with the ps pump?
my hood seems to be just resting on the top of the hose that connects the ps pump to the resivor....
My set up is a k20z1 with the jmercedo bracket and no spacers. 05 rsx type s
Old Feb 8, 2010 | 05:39 AM
turboteg2nv's Avatar
Default Re: jrsc install
Did you pull the ECM fuse when you removed the battery? Usually people do this to prime the engine with oil before the initial cold engine start.
Did you hook up the battery correctly? Serious questions lol. (+) to (+) and (-) to (-)?
Old Feb 8, 2010 | 08:54 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Here is my solution to your power steering problem.
I can sell you mine if you'd like since I'm no longer running power steering
http://forums.clubrsx.com/showthread.php?t=650178
Old Feb 8, 2010 | 02:27 PM
turboteg2nv: yes lol thats the first thing i went and checked to make sure it was right.
I checked the fuse under the hood and it seemed to be okay idk maybe it did drain having it out all weekend im not sure
Old Feb 9, 2010 | 05:01 AM
Throw a battery charger on it and see what happens. You are from WI so it's probably a balmy -50'F out there.
Old Feb 12, 2010 | 04:04 AM
SiLkk's Avatar
Make sure the ground wires are reconnected.
Old Feb 12, 2010 | 06:16 AM
iv's Avatar
iv
Sound like a ground wire issue to me also
slowesteg
Jun 27, 2015 01:49 PM
polymerman
Honda Civic (2006 - 2015)
Jan 12, 2014 06:36 PM
Jper
Apr 27, 2009 01:07 AM
kinvid22
Jul 23, 2004 10:19 PM
