fs turbo b series misc.
Old Feb 7, 2010 | 08:39 PM
FlatBlkEk's Avatar
Default Fs:Turbo and B Series Stuff More parts added
I'm not gonna put prices on anything i just want fair offers. Pm me with the item(specifically)you want, your offer and any specific questions you have about that item. If you don't follow those simple steps then i will assume you are attempting to waste my time and are more than likely flakers and will be ignored. I will ship immediately after receiving payment via paypal... My PAYPAL ADDRESS IS xxelusive@gmail.com Once again My PAYPAL ADDRESS IS xxelusive@gmail.com.
Trades are welcome.Ill take ek hatch parts interior or exterior, anything for a 99-00 hood as long as its oem, Sk2 cams, b series headers and 2.25/2.5 full exhaust.
Low Ballers Welcome but doesn't mean I'll settle for your offer.
EVERYTHING IS GUARANTEED NOT TO BE DOA, FULL REFUND NOT INCLUDING ORIGINAL SHIPPING. YOU PAY RETURN SHIPPING!
Please bump if you view and ill return the favor.
I have a lightly used turbo setup for a single cam.
Bnib Precision 440cc injectors
Xs power t28 turbo,down pipe and manifold(used)
Intercooler and piping (used)
HKS super sequential BOV (used)
Bnib B&M fuel pressure regulator + gauge
Bnib Walbro Fuel Pump w/ install kit
Blocks
1.Bare Ls block no crank
2.JDM B16 short block fully assembled came from a running car will send pics upon request then will probably upload here if the interest is there.(mileage unknown bought it from a friend and ran it till i was done building a ls/vtec)
Im parting out a 93 integra, heres what i have.
1.B18a1 integra transmission that could use a rebuild. Make an offer
2.Doors. Comes with window glass, window motor and regulator and mirrors. Original black oem paint (Has everything minus the door panels. Doors are 7 out of 10)
3.Exhaust from catback
4.Complete a/c system (yes fully functional, worked fine till the day i pulled it out.)
5.Front Fenders (original black oem paint)
6.Front calipers(oem nissin remanufactured calipers, fairly new)
7.Brake master cylinder
8.Shift linkage and ****
9.Clutch,Pressure Plate and Flywheel (for ys1 92-93 transmission only)
96-98 front end of a civic hatch all painted flat black (yes with a can and not sealed)
Aftermarket Fenders (small imperfections that can be sanded and repainted)
Bumper (cut so the inter cooler can fit)
Head Lamps
Front Bumper Support Cut and Modified with a steel bar across the back of it so an intercooler can sit right inside and bolt to the top of it
Ebay mesh grille
Oem Hood There's a small dent from a tial wastegate when the drag kit was on it and the previous owner of the vehicle shut the hood without checking clearance.
EK coupe dark grey manual door panels (good condition)
Ek 4dr Side skirts black
Power Steering pumps
p2a(96 civic)
po2(92 civic)
jdm pr3 (aem pulley)
Ek Clutch pedal, master cylinder,lines
Ek dark grey steering wheel
-10 weld bung
Forced Performance -4an Filter .030 orifice (bnib)
B series oil pan with -10 bung welded
More water pipes for b series motors
92-95 civic ex harness
b series mount for eg
box 'o' drain parts (all pieces are -10an , full race drain line fittings,and misc)Lmk what you need from the box. If you want all the contents in the box then understand what the pieces are worth before making an offer.
turbo feed (3 are -4an and one is -3an)
Resistor boxes cheap fuel pressure regulator and a civic fuel pump
Ls/V Golden Eagle-Complete and ARP head studs-Missing some nuts and washers ( both sets torqued once)
Catch Can misc parts
Coolant crossover pipes (2 are dohc vtec the other is a da pipe. The thermostat housing i can sell seperately or with a vtec pipe.)
Sohc vtec parts ( 1994 Honda Civic Starter Motor (Mitsuba) (4), 2DR EX KA 4AT E(bench tested)/honda oem timing belt in good condition/ everything else is in good working order)
DA parts (all in good condition)
P30 flywheels
EK Steering wheel (great condition )
3in short turbo filter
3in turbo filter
B series oil pan -10an welded bung mid
B16 oil pan
Bosch Fuel pump
Ls/V dowel pins
Map Sensor
Gsr Crank positioning sensor
H22 parts (brand new timing belt still in package, new shift **** and one brand new oil pressure sensor the other is used)
Gsr parts (ps pump and bracket,(girdle is sold),cooler and cable)
Brand new 88-91 civic clutch cable and log manifold drain parts
A set of dark grey power door panels from an ek coupe
EK coupe passenger side light grey power door panel
Manual 99-00 civic harness sold
Greddy Catch Can sold
ek bracket sold
Boost controller sold
Sk2 springs and retainers sold
jg throttle body sold
B series oil pan -10an welded bung high sold
B16 manifold and gsr girdle is sold
ACT clutch and flywheel (KdF)
EK intercooler piping(gooberguy31)
Endyn catch can (dh-r)
RC 750cc injectors (sold to DUKE LADUKE)
ls oil pan sold
Old Feb 8, 2010 | 01:07 AM
eaz_e's Avatar
Default Re: fs turbo b series misc.
No reason BUMP!!
Old Feb 8, 2010 | 03:41 AM
FlatBlkEk's Avatar
ttt
Old Feb 8, 2010 | 06:26 AM
johnls's Avatar
pmed
Old Feb 8, 2010 | 09:12 AM
hardcore97's Avatar
pm me what you want for the headstuds shipped to 65066
Old Feb 9, 2010 | 03:23 AM
FlatBlkEk's Avatar
up
Old Feb 10, 2010 | 05:43 AM
b20beast83's Avatar
pm me a price on valve springs
Old Feb 10, 2010 | 10:18 AM
bmorei9s08's Avatar
pm price shipped to 21234 for the intercooler piping. thanks.
Old Feb 10, 2010 | 10:43 AM
ivt-t's Avatar
need price for fittings,turbo feed,endyn catch can,both sets head studs,catch can misc partsact clutch,ek piping
pm me please
Old Feb 10, 2010 | 12:09 PM
Unsivil_audio's Avatar
lots of good stuff here, bump.
Old Feb 10, 2010 | 02:37 PM
FlatBlkEk's Avatar
thanks !!! TTT
Old Feb 11, 2010 | 03:21 AM
FlatBlkEk's Avatar
all pm's replied
Old Feb 12, 2010 | 07:07 PM
FlatBlkEk's Avatar
back up
Old Feb 12, 2010 | 08:45 PM
phxz6's Avatar
pm'd
Old Feb 15, 2010 | 03:05 AM
FlatBlkEk's Avatar
Im open for trades also. So lmk what you have ...."and lets make a deal".
Old Feb 15, 2010 | 11:20 AM
KENNYbuiltEG6's Avatar
money has been sent for the hondata intake gasket... thank you
Old Feb 16, 2010 | 09:36 AM
Bump because I looked again. PM me a price for those ls/v headstuds.
Old Feb 17, 2010 | 04:09 AM
FlatBlkEk's Avatar
pm's replied ..............items going out for delivery today
Old Feb 18, 2010 | 01:32 PM
FlatBlkEk's Avatar
items shipped lets do it again
Old Feb 22, 2010 | 03:36 AM
FlatBlkEk's Avatar
pm's replied.....injectors shipped thanks you for your purchase
Old Feb 22, 2010 | 09:04 AM
dh-r's Avatar
pm me a price for the endyn catch can
Old Feb 22, 2010 | 01:04 PM
FlatBlkEk's Avatar
up
Old Feb 23, 2010 | 03:36 AM
FlatBlkEk's Avatar
pms and emails replied
Old Feb 23, 2010 | 06:27 AM
turbohatch96y7's Avatar
How much for the endyn can ?
Old Feb 24, 2010 | 04:47 PM
bump for a great seller.... buy with confidence i bought the hondata intake manifold gasket and arrived in great shape
