RS*R Header
Up for sale is a RS*R Header for B series engines. The header is in great shape with minimal damage on the bottom due to scraping and bottoming out. Otherwise it could use a good cleaning from sitting around for a while. No trades unless you have jdm crx parts. (818) 621-8971
$200 or best offer
$200 or best offer
Okay I just got a notice from my landlord to remove "all the crap" from the garage floor. So I need this gone tonight the latest tomorrow night. Price drop to $150 before I put this in my bros B16.
Looks as if the header has a straight piece welded on, extending to meet the B pipe and bypassing a cat all together. The o2 sensor would technically be where the cat converter would normally be found.
You are correct. It has an o2 sensor at the bottom near the additional pipe but it's been plugged up.
They will definately fit. Either way you can take it to a muffler shop and have then weld it on or cut it at a particular spot to fit your current set up. I know a few shops that will do it for about $20 if need be.
99SlammedCivic
Aug 4, 2007 06:42 PM
J2turbo21
27
Jul 6, 2003 09:45 PM
