problem after installing headers...
Old Sep 5, 2002 | 08:33 PM
wizzards581's Avatar
Default problem after installing headers...
sometimes when i accelerate... feels like the engine goes weak... feels like your ac is on 10x or something... this happens to me alot now.. and when i push the gas harder it goes weaker... whats wrong?? it happened after i installed headers...
Old Sep 5, 2002 | 09:11 PM
Kamin's Avatar
Default Re: problem after installing headers... (wizzards581)
when in the rpm range does this happen
if it happens down low (below 3000) then its normal, once you install a high flow headeR (no s, only 1 on a honda) you loose low end.
Old Sep 6, 2002 | 07:42 AM
Default Re: problem after installing headers... (KAMiN)
its normal??? i dont think its normal... yes it happens between 2k to 3k rpms.. after 3k... nothing happens... but this really bugs me alot... today i accelerate up a hill and this happened again... my went so weak that cars in the back was gona hit me... i hate it... is there a way i can do to avoid this happening???
Old Sep 6, 2002 | 07:47 AM
Jason kiDD's Avatar
Recheck your header bolts and make sure that the nuts are all tightened if you didnt do so already. After you have installed them bolts its always good to recheck them for fitment since the header is now warm and has had a chance to expand. You may be leaking out exhaust out the headers..
H23_Lude4_2_0
Oct 21, 2010 11:28 AM
bbhockey19
11
Aug 10, 2006 06:05 AM
bust_on_fools
May 13, 2005 05:41 PM
bardo
Jul 27, 2004 06:44 AM
DARKsideLS
Jan 5, 2003 12:02 AM
