b20b build ..ideas!! 200hp
parts list ..
b20b block, new seals,acl bearings (part # wanted), ITR oil pump, ITR water pump,
arp rod bolts, golden eagle conversion kit with headstuds, 84mm rs machine ITr pistons.
hytech replica tri y header, 3 inch b pipe . 2.5 inch c pipe (axle back)
head is a complete ITR head ,intake manifold and tb .
310 cc injectors,upgrade fuel pump, ECTune
Questions
1) Can i make 200hp with the ITR cams and valvetrain or should i go with the skunk 2 pro2
2)any other recommended upgrades
Questions
Completely wrong......... On every count
You may see 200hp if not quite close depending on your tuner.
Sounds like a fantastic build.
with better pistons,valvetrain,cams mabey a port job
it would see that befor a tune....
the rs machines itr pistons will give him at least 11.5:1 compression and thats if the head has never been decked im it has been or will be so he will be at around 11.7:1 comp i say thats high enough for 200 whp or very close to it
im hoping that my build will get me 200 whp also but im running
srp 10.5:1 compression pistons with a head milled .010 which will give me 11.0:1 compression
the head is a mildly ported gsr head
skunk 2 intake mani
skunk2 tuner stage 1 cams
eagle rods
jg edlebrock 65mm tb
megan header
tanabe 60mm exhaust
havent figured out what injectors i wanna run yet not sure what size i will need
tuned with neptune
im hoping for 190-200 whp
skunk 2 intake mani
eagle rods
megan header
tanabe 60mm exhaust
tuned with neptune
When will the misconception of compression end.
OP, look through the dyno thread at the top of the page. You will find multiple builds with your whp number with pump gas friendly compression.
skunk 2 intake mani
eagle rods
megan header
tanabe 60mm exhaust
tuned with neptune
skunk 2 intake mani
eagle rods
megan header
tanabe 60mm exhaust
tuned with neptune
[QUOTE=dm23;41497519]parts list ..
Questions
2)any other recommended upgrades[/QUOTE
if you do go with skunk2 pro 2's with the rest of the parts you mention you should make 220whp-235whp with good tune hondata s 300 if your comp is 11.1.
I made 210 on 1.8itr 11.1comp
Questions
parts list ..
Questions
Questions
b18 block
p30 pistons
b16 head milled ported with itr cams
itr im
jasma headers
Bump.i am debating goin b20v. Those pistons should be fine. I would suggest an s300 complete valvetrain. And an edelbrock intake mani. Tuning is the key here not your compression. Like he said its a 2.0 not a 1.8 any more
germanegturbo
Sep 27, 2008 01:30 PM
ATTENTION HT MEMBERS SUPER SALE EVERYTHING MUST GO THIS WEEK b20ZVTEC ITR TRANS ITR SEATS ITR HEADER
sleeplsm
May 31, 2007 09:54 AM
