Transmission & Drivetrain Gearboxes, Differentials, Clutches
Converting CRV Rear Diff from real-time to "full-time"
Old Feb 7, 2010 | 04:15 AM
fastshift's Avatar
Default Converting CRV Rear Diff from real-time to "full-time"
I've been doing some research. I've learned that the AWD in CRV's are real-time which means it isn't always 4WD, in fact, rear wheels get powered only when the front wheels slip.
It is operated by dual hydraulic pumps that delivers power to rear when there is a pressure difference.
And I was wondering if anyone ha converted it so it is full-time 4WD. Would it be as simple as just taking the pump portion off of the diff assembly? or am I better off looking for a different diff with no hydraulic pump mechanism?
Thanks
Old Feb 7, 2010 | 05:49 PM
fastshift's Avatar
Default Re: Converting CRV Rear Diff from real-time to "full-time"
bump
Old Oct 27, 2010 | 07:12 PM
gmcuajo's Avatar
Anything on this?
Anyone has modified it to obtain more torque on the rear wheels, like boring fluid passages or modifying cluthches?
Old Oct 28, 2010 | 05:54 AM
unusual71's Avatar
iirc the system in the rear is only designed to take a max of like 20-30% of available tq in the rear. Not sure if the system can be overridden or cheated or whatever, but my suggestion is, if you need a more competent 4wd system you should start looking into options other than the crv.
Old Oct 30, 2010 | 11:28 AM
BWilson484's Avatar
What is the benefit of having AWD all of the time versus when the front slips.. just curious
Balor_Gr
AWD Conversion Forum
20
Jul 8, 2021 06:24 AM
mchkc240
Honda CR-V & Element
Nov 25, 2015 04:11 AM
gnarly fbpem1
Feb 21, 2012 12:51 PM
si90rex
Sep 12, 2011 09:20 AM
chet
10
Jul 20, 2006 10:30 AM
