Honda S2000 Honda S2000
question about replacing tires on ap1 rims
Old Feb 6, 2010 | 05:27 PM
CivicSi95's Avatar
Default question about replacing tires on ap1 rims
should i go with a 245/45 rear tire that is as close to the 8.5" tread width of the oem bridgestone s02's? or should i just go with a 225/50 tire with as close to the 8.5" tread width of the s02's? i do not want to go with s02's because i need some rain traction. this is not my daily driver
Old Feb 6, 2010 | 10:18 PM
chubbylee240's Avatar
Default Re: question about replacing tires on ap1 rims
im running 225 50 fronts and 245 45 rears. there fine to me. (falken rt615). dnt know if that helps
Old Feb 6, 2010 | 10:54 PM
vsm_EJ6's Avatar
Why do you need rain traction of this is not your daily driver? Go with the 205F 225R. You'll be fine. Or opt for 17s which offer a better availability in tire size for the s2000s.
Old Feb 7, 2010 | 09:58 AM
Black S2K's Avatar
btw not too many tire manufactures make a 245 with 16" tire anymore
Old Feb 7, 2010 | 12:11 PM
HondaKyle's Avatar
205s?! those things are cookie cutters. OP get 245s you wont regret it.
Old Feb 7, 2010 | 10:34 PM
vsm_EJ6's Avatar
...Where is he going to get 245s? Please, link me. So I can get them as well. Find me a 215 for the front and a 245 for the rear. I will purchase them tomorrow if you can provide me a link. And I'm talking about a decent tire, not all season or tires that feel like plastic.
So if OP was to put 245s on the rear of his car, he can go with a Continental ContiSportContact, Fuzion ZRi, or Yokohama AVS ES100.
So if he was to select one of those tires for the rear, what tire is he going to go in the front? Cause I'm not sure where to get the 205/55r16 in that brand. So he'd have to go with a mismatch tire.
Anyways, theres a million tires out there in a 205/55r16 and a 225/50r16 that has greater capabilities than any of the tires above even with them being 245s.
OP can get Bridgestone Potenza RE-11, Dunlop Direzza Sport Z1 Star Spec, or Yokohama ADVAN Neova AD08. tirerack has recently done a comparison test which puts the RE-11's ontop of the other two.
And if you're so concerned about tread width.. (considering the fact that the Potenza S-02's which are 225/50r16 but actually have a contact patch of 8.5" which puts them closer to a 245/45r16..) then go with the OE tires. That simple.
I'll say this over and over again, tread compound > tread width.
If you're so concerned about upsizing then you need to find some 17" rims. That will allow a better selection of tires in appropriate sizes for the S2000.
So again, a 205/55r16 front or a 225/50r16 for the RE-11's or StarSpecs will be your best bet for handling on the vehicle. They will handle better than any larger tire that is far less superior than the ones I listed.
Old Feb 8, 2010 | 04:02 AM
HondaKyle's Avatar
WOOOO, broheem chillaxxx. I'm more into the straight lines.
SlowEJ8
Jul 21, 2009 01:25 PM
BB1LOViN
Dec 20, 2007 04:46 PM
zad5
Aug 31, 2006 08:08 AM
01itr320
Honda S2000
May 28, 2005 10:36 AM
sidious141
Sep 18, 2004 09:23 AM
