are bigger valves necessary to make more power ?
Old Feb 5, 2010 | 05:37 PM
H-allmotorda9's Avatar
Default are bigger valves necessary to make more power ?
im building a b18a1 head. im port matching it. but do i need to go with over sized valves to make more power. and can i use gsr valves ?????
Old Feb 5, 2010 | 05:39 PM
flesh199's Avatar
Default Re: are bigger valves necessary to make more power ?
look for a p8r non vtec head.They already have the 33 mm intake valve in it.
Old Feb 5, 2010 | 05:40 PM
00Red_SiR's Avatar
All Motor Mentor
Having the head professionally ported is much better than simply installing larger vales which will accomplish very little. Once the head is done, you'll need to select cams, intake manifold, header, exhaust, pistons, tuning system....all the things that COMPLIMENT each other and power will be made.
After saying all that, there's a reason why people go LSVTEC, which is because those heads stock out flow your current head and have the potential to flow more than your current head ever will.
Old Feb 5, 2010 | 06:30 PM
yeah i got crower dual springs steel retainers, skunk 2 mani, bdl 68mm TB, crower 404s. ready for the head
I HAVE A BUILD ON HERE.... N/A NON VTEC B18A1
Old Feb 5, 2010 | 06:35 PM
1.5Slowmatic's Avatar
if the chamber is opened up, the throat is and the rest of the port is tailored for it than they will work but just putting the valves in a stock head isn't worth it
Old Feb 5, 2010 | 06:39 PM
yeah true... but i know i can make that head flow good and run harder then a vtec....
Old Feb 5, 2010 | 06:41 PM
Natural Aspirations's Avatar
No you cannot use GSR valves the have a different stem diameter.
Non-Vtec builds are great they just arent great drag race motors, I use one for my autocross car and it works fantastic.
Old Feb 5, 2010 | 06:43 PM
well am draging mine... i wont at least a 13.4 ill be happy with that
Old Feb 5, 2010 | 06:47 PM
[QUOTE=Natural Aspirations;41485227]No you cannot use GSR valves the have a different stem diameter.
ok i was just asking cuz i might get a gsr head... yeah i know not use that n go ls/v... cuz i already got **** for my ls head. i might the gsr head too. if anydody wants it. 450. full head no dizzy tho. and a edelbrok mani for 150
Old Feb 5, 2010 | 06:48 PM
No you cant with equal mods a vtec motor of similar displacement will always out perform one with a non-vtec head. Its not that they wont perform great but there are some limitations of the head and rocker designs. One thing I have herd of was someone who had their p75 (or p8r I forget) head cnc machined with PR3 ports achieving better flow but you still have the rocker limitations.
Old Feb 5, 2010 | 06:52 PM
horrible price on the head decent price on the manifold.
Old Feb 5, 2010 | 06:54 PM
idk ima cn if i dnt like it ill go vtec i guess n be like everybody else ugh!!! that said can i use a gsr head with p30 pistons ??? n have VTP clearance ???
Old Feb 5, 2010 | 06:58 PM
the head is fresh man w/ cams
Old Feb 6, 2010 | 12:32 PM
h23V's Avatar
I have a question. Has anyone ever just go bigger on the exhaust side like 1mm over and just leave the intake alone. B/c getting the exhaust out better raise the potential of the hp/tq almost like retarding the exhaust cam only. Alot of people do that when using nitrous.
Old Feb 6, 2010 | 05:02 PM
00Red_SiR's Avatar
All Motor Mentor
The difference is that during the exhaust cycle, the burned mixture is under pressure to escape. As long as it has a reasonable exit available and it's open long enough, it'll get out. In an NA motor, the intake charge must be sucked in and isn't pressurized like it would be in an FI setup. Using a longer intake pipe/longer runner IM/larger intake valves/better valve job/etc are all ways of increasing volumetric efficiency. Adjusting cam timing on the exhaust can help but so will a well designed header and free flowing exhaust.
Old Feb 6, 2010 | 05:05 PM
SergEK's Avatar
No you wont
Old Feb 6, 2010 | 05:57 PM
4piston's Avatar
A good rule of thumb is that you see about 10 cfm for every 1mm increase in valve size. There are other ways to get flow, but usually when you go to the larger valve you run a larger throat and bowl as well, so you can considerably increase flow if you know what you are doing.
Old Feb 6, 2010 | 07:40 PM
h23V's Avatar
Understable so do u think that u would get good gains from increasing exhaust side only to help exhaust scavenge the cylinder just like a big long tube race header and 3 inch exhaust i mean if u can make power all the way around the power band hp/tq with just changing exhaust from 2.3 to 3 inch and a good race header thats stepped in the right places it does make sense. maybe even better than changing both sides b/c the honda intake flows pretty damn good from the jump. But just some assumptions i was thinking on the subject.
ek9=]
Sep 22, 2008 05:58 PM
AntMan401
Mar 17, 2008 02:13 PM
xplanetearth420x
Oct 23, 2005 05:23 PM
VaporTrail
Oct 18, 2001 10:40 AM
