Suspension & Brakes Theory, alignment, spring rates....
bouncy rearend with h&r springs but im thinking its the struts
Old Feb 5, 2010 | 04:08 PM
lyncoors's Avatar
Default bouncy rearend with h&r springs but im thinking its the struts
are h&r good springs. are they too soft. also i think i have a toe problem the inside of my pass. side tire is worn on the inside and the steering wheel wobbles alittle bit. any help please
Old Feb 5, 2010 | 09:34 PM
lyncoors's Avatar
Default Re: bouncy rearend with h&r springs but im thinking its the struts
so alignment and shocks it is i guess
Old Feb 6, 2010 | 07:35 AM
Egezzy's Avatar
Spongebrad Squarepants
sounds as if you tie rods are shot and yes your dampers are probably done in the rear.
Old Feb 6, 2010 | 07:52 AM
kommon_sense's Avatar
H&Rs are excellent springs. However this post is too vague to give any real guidance.
Which H&R springs are you running? H&R OE sport? H&R Sport? H&R Race? What shocks are you running and how old are they?
As for tire wear, not necessarily your tie rods, but you should inspect them. You may simply need an alignment. When you lower a car, it naturally toes out and you do an alignment to bring toe back into the proper range. 0 toe up front is a good starting point.
To check your dampers, simply press down on each corner of the car with your full weight. It should be firm and move up/down consistently. If it moves up/down too freely to the point of being nearly bouncy, then yes, probably time for new shocks.
With 60% of the weight being on the front, stiffer springs on the front, and more abuse on the front, it is unlikely that your rears are blown (without fronts being blown as well). Point here is that the rears don't do much work and see little abuse, *UNLESS* the car has not been properly maintained.
Old Feb 6, 2010 | 08:35 AM
Egezzy's Avatar
i think that answers that. lol.
Old Feb 6, 2010 | 05:02 PM
lyncoors's Avatar
thanks, sport springs. and yeah shocks are shot
Old Feb 7, 2010 | 05:18 PM
lyncoors's Avatar
just by looking at it looks like the toe is off. new struts are going to be ordered
Old Feb 7, 2010 | 08:03 PM
imptricer's Avatar
mine road fine stock height eg with 220k put h&r race springs on it same thing people would seriously hit there head on the roof in the back on a bump new struts fixed my problem i could pull the dampener in and out they were shot
Old Feb 7, 2010 | 10:28 PM
lyncoors's Avatar
yeah i just baught this car and yeah its the rears are bad
Old Feb 8, 2010 | 07:39 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
H&R Sport springs are junk. Way too soft for the amount they drop.
Old Feb 8, 2010 | 01:16 PM
lyncoors's Avatar
reason to change lol
wesk18
Dec 15, 2009 03:29 PM
spyderracing
25
Jun 17, 2004 11:20 AM
skrigz
Jan 29, 2004 02:22 PM
Hunter
22
Feb 22, 2002 02:44 PM
LoneWolf
Jul 5, 2001 10:05 PM
